Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 10-09-2009, 05:11 AM
  #10411
Mr_Gleeman's Avatar
Trader Rating: 16 (100%+)
Default Must see video clip!!
And now for something different, check out this bit of You Tube vision we put together from our indoor midweek racing here in Oz. Have a Look!!
Cheers
John
Mr_Gleeman is offline
Old 10-09-2009, 05:55 AM
  #10412
subaru73's Avatar
Trader Rating: 42 (100%+)
Default mo5
just found this morning mo5 hop up pictures from tamiya.
http://www.tamiyausa.com/articles/fe...article-id=440
subaru73 is offline
Old 10-09-2009, 06:44 AM
  #10413
R/C Tech Elite Member
monkeyracing's Avatar
I can't believe they've split the steering gear into 3 separate hop ups! Expensive, too.
I do want to try the new ball diff though.
Jim
monkeyracing is offline
Old 10-09-2009, 07:56 AM
  #10414
nozauta619's Avatar
Questions??
Any difference with the M-05 ball diff versus the TA03 ball diff?
nozauta619 is offline
Old 10-09-2009, 08:06 AM
  #10415
Jam-ehz's Avatar
I think all you'd really need is the steering arms to lessen the slop.. the posts are stationery, it's more convenience than function, and the link is just a solid bar, it'll be clamped down on the small bearings of the arms, so the aluminum one won't have much effect either.
As for the diff, it's basically a Touring car diff, all nice and smooth when brand new.. without wrenching the hell out the thin screw and risk breaking it, how would we tighten it to reduce the diff action? At least with the TA03 diff we could just add another washer/shim or two, screw it down tight, and voila! No worries..
It'd be great for the M04, only if it fit...
I wonder if they'll be selling spare diff gears sometime..
Jam-ehz is offline
Old 10-09-2009, 08:11 AM
  #10416
dannyboy15's Avatar
Default diff
how do u know that ur mo3 diff is about to give out?
dannyboy15 is offline
Old 10-09-2009, 08:31 AM
  #10417
Jam-ehz's Avatar
Even if tightened it should still feel pretty smooth when rotating the diff, not like it's full of sand.. there are a couple things that could give..
If it doesn't rotate smoothly, dismantle and clean everything really well, and test the diff balls (assemble the diff without the middle screw, and rotate while pressing the halves together) and the thrust bearing (rotate it while pressing between your thumbs). They should be very smooth when rotating.
If not, replace the diff balls, flip the plates, or just sand the existing grooves out with fine sandpaper laid on a flat surface. In the case of the thrust bearing, they sell them separately.
Then, pack the thrust bearing good with AW grease, just barely touch the diff balls with some diff lube, assemble, and rotate the diff for a minute on a drill at med-low speed. I use a hex driver bit to turn the screw while holding the gear. Test the diff movement, and tighten/adjust the screw accordingly. Things should be much smoother.
As for a gear diff, well, look at the gears for significant wear, but I've found they last pretty well with some lube in it. It's often the inner teeth that grip the driveshaft that go, but there isn't much warning for that..
Jam-ehz is offline
Old 10-09-2009, 08:44 AM
  #10418
dannyboy15's Avatar
its a gear diff
if u spin both wheels by hand it is smooth but as soon as u drive one it is horrible and graunchy
Old 10-09-2009, 08:58 AM
  #10419
Hyde's Avatar
Originally Posted by tony gray
Due for release 22nd October...
wow that's ugly! They should have came out with the original!
Hyde is offline
Old 10-09-2009, 10:25 AM
  #10420
Jam-ehz's Avatar
Originally Posted by dannyboy15
its a gear diff
Heh.. we don't call the Mini class the "Coffee Grinder class" for nothing..
Yeah, spun with no tension it's fine, but the pressure of the drivetrain will always make them loud as hell.. sure, try AW grease or something really thick, but the noise often can't be helped..
Jam-ehz is offline
Old 10-09-2009, 11:23 AM
  #10421
scribbler's Avatar
Has anybody seen the new ball diff for the M05? I'm interested in knowing if the cups that secure into the diff are slots like the new gear diff, or if they have the same spindles?
scribbler is offline
Old 10-09-2009, 11:59 AM
  #10422
Shake's Avatar
Me likes it....
Shake is offline
Old 10-09-2009, 12:00 PM
  #10423
tamiyarcracer's Avatar
here is the link to the diff, maybe you can answer the question yourself, cause I don't understand what your asking.
M05 Diff
tamiyarcracer is offline
Old 10-09-2009, 12:04 PM
  #10424
AWK
AWK's Avatar
http://www.tamiyausa.com/product/ite...oduct-id=54194
AWK is offline
Old 10-09-2009, 12:15 PM
  #10425
Andrew,
Do you know if the diff rings/plates are from the 501X?
