Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 07-29-2009, 07:17 PM
  #9661
Smile
It fits swift civic ae86 240z.......etc, except mini.
rcpinky is offline
Old 07-29-2009, 07:48 PM
  #9662
225mm? Don
DLS II is offline
Old 07-29-2009, 08:10 PM
  #9663
I just finished building a Mini M03.
Upon hard acceleration, the steering servo has one hard twitch which initially throws off the steering.
any thoughts? or it that what's expected?
I'm using an old futaba 3003.
Will a new servo help remedy this problem?
is digital servos any better?
MiniU4IA is offline
Old 07-29-2009, 08:32 PM
  #9664
hairy's Avatar
hold the car so that front wheels are of the ground and pull the trigger and see if it twitches without a load on the front end, if it does then check the mounting for your a servo and make sure it is all thight, or you might try another servo. if it does not do it when you try it then i would look for a bind in the drivetrain. Good luck
hairy is offline
Old 07-29-2009, 08:44 PM
  #9665
Glad to see I didn't steer you wrong
bowl806 is offline
Old 07-29-2009, 09:08 PM
  #9666
MiniU4IA is offline
Old 07-30-2009, 05:04 PM
  #9667
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Wewt! Got my M05 Pro. These shocks are the same as on the M03R right? So I'm guessing I shouldn't run them since they crack like glass.
Dan is offline
Old 07-30-2009, 07:25 PM
  #9668
doriftu's Avatar
do you have have this problem using TRF shocks when mounting on M05?
there is about 2mm play between the shocks and the screw at the shock mount. . This problem is the same at the front and rear.
how do you guys eliminate this problem besides using the ball connector?
doriftu is offline
Old 07-30-2009, 08:31 PM
  #9669
Dan
Dan's Avatar
I have the TRF shocks on my TA03R and you have to use the ball connectors for that plastic shock cap end. I think they're either 4mm or 5mm sized.
Dan is offline
Old 07-30-2009, 08:32 PM
  #9670
Default M-03 Hobbywing motor/ESC
Need some help mates- Been reading up on M-03 build ups and my Mini is currently powered w/MM 7700 2s4000 which I cloned from Suzuki Swift in RCCar Action and stuck it in a Mini: I am located in the Central Calif USA --which hobbywing motor/ESC combo are y'all using to race with in the land down under? Also what type of gearing would be suggested for sort of a gritty track--stock setup?
Thanks!
bowl806 is offline
Old 07-30-2009, 09:00 PM
  #9671
Trader Rating: 21 (100%+)
In Australia we are using Hobbywing Brushless ESC and 3000 kV Motor(13T).
The rule is that you have to use a Hobbywing OEM or rebranded COMPLETE
SYSTEM with max 25 or 35 amp ESC and the motor has to be engraved/etched.
l337 is offline
Old 07-30-2009, 09:11 PM
  #9672
caltek1's Avatar
Trader Rating: 38 (100%+)
doriftu,
I am using ball end connectors with a o ring fitted, to help prevent the shock cap from being pushed over the ball completely. I used a 5mm ball connector witha 8mm length shaft for the top shock mounts so you can still fit the 3mm spacer.
Regards,
Calvin.
caltek1 is offline
Old 07-30-2009, 09:27 PM
  #9673
Thanks for the feedback! is it sensored or sensorless--any difference?
Thanks again 1337!
bowl806 is offline
Old 07-30-2009, 09:33 PM
  #9674
mcdogboy's Avatar
Unsensored.
mcdogboy is offline
Old 07-30-2009, 09:42 PM
  #9675
Talking
Originally Posted by mcdogboy
Unsensored.
Thanks! It's time for a change from my MM7700.
bowl806 is offline
