Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 08-20-2015, 01:44 PM
  #25411
eR1c's Avatar
Does anyone know of any club that races a Tamiya WR-02 class?
(this is the Tamiya VW bus, Tumbling Bull Tractor, Willys Jeep, Turbo Honda, etc... )
eR1c is offline
Old 08-20-2015, 01:55 PM
  #25412
sakadachi's Avatar
I don't know, but I have a WR02.
OT:
I remember back in the 80's they raced WildWilly's on TV in Japan. But if anyone's planning to get one, get the GF01 instead. You can fit the Wildwilly body on it with minor tweaks, two rear WW2 wheels, and have 4WD. I have 2 of them.
sakadachi is offline
Old 08-20-2015, 02:12 PM
  #25413
eR1c's Avatar
Which WR02 do you have (what body)?
I saw the Honda Turbo in the latest edition of RC Action magazine, ...went online and saw some sweet builds. Looks like a lot of fun!
eR1c is offline
Old 08-20-2015, 02:14 PM
  #25414
eR1c's Avatar
-Actually that Suzuki Jimmy looks pretty darn cool too.
I have an area on the side back yard that isn't being used for anything ...thinking an off-road track for something like one of these would be great.
eR1c is offline
Old 08-20-2015, 02:16 PM
  #25415
sakadachi's Avatar
eR1c- I'll send you a PM since off-topic.
Old 08-20-2015, 02:38 PM
  #25416
Originally Posted by sakadachi
Is it from the impact hitting the asphalt? If so, can a skid plate help?
Take some of the weight off the top, place it on the bottom using brass, raise height by 0.5mm to offset.
I usually raise the height by 6-7mm when I take my cars outside. This is another reason why I hate taking my cars outside because I have to change the setups back and forth between parking lot and my track... with the M05/V2 tracking issues with the rear left ride height, just a hassle dialing it back in while perfecting the even wheel gaps with the body as I like my models to look like real cars.
I think the reason it cracked like that is because I am a shocking driver. My car cops a beating on the track. It's not uncommon to see my car cartwheeling off the track. This is obviously just the weak spot.
filippimini is offline
Old 08-20-2015, 02:41 PM
  #25417
sakadachi's Avatar
I see... I was just wondering if there was a quick way to prevent or at least prolong the life of the chassis.
Old 08-20-2015, 03:52 PM
  #25418
(0000000000)'s Avatar
Th hinge that connects the A-arm to the frame is a known weak point. Several guys at the local tracks have cracked their V2 frames in that specific area. Jim was just the latest casualty. Might have been the plastic used in that batch of A-parts trees.
Jim, did you have the droop screws installed when you broke in edmonton? I'm wondering if the screws are adding pressure to the frame.
(0000000000) is offline
Old 08-20-2015, 06:39 PM
  #25419
R/C Tech Elite Member
monkeyracing's Avatar
Yeah, but the seats were reinforced. It was just the crack propagating due to continued abuse. I knew the car was getting wrecked that day!
monkeyracing is offline
Old 08-21-2015, 01:53 AM
  #25420
Check out the racemonster that is the MF-01X 4WD Suzuki Jimny!
+ YouTube Video
Thaan is offline
Old 08-21-2015, 02:26 AM
  #25421
Tim K's Avatar
Thanks for posting that video, it looks like it handles great!
What motor are you using?
Tim K is offline
Old 08-21-2015, 05:47 AM
  #25422
sakadachi's Avatar
Yeah, that's a busy truck indeed!
Fabricated a M03 rear swaybar on my M01. Drives very well with natural amounts of body roll now.
Used a friction damper shaft for the arm side wtih ball end collar + nylon locking nut.
The bracket is an M05 servo mount piece with screws to box the bar in place.
I put 2 rubber collars on the bar itself to lift it from the chassis.
Tonight I will work on the steering linkage to make the posts more refined.
Old 08-21-2015, 06:33 AM
  #25423
patorz31's Avatar
+ YouTube Video
Does anyone know the internal ratio of the 4wd? is it the same as the M05?
patorz31 is offline
Old 08-21-2015, 08:43 AM
  #25424
Nope. I think you can get it close with the speed tuned gears, but out of the box, it's around 9.5:1.
Old 08-21-2015, 08:54 AM
  #25425
sakadachi's Avatar
That truck wasn't intended to be raced like that, right? The Tamiya folks were saying a small convenient truck to roam around where ever you want (like inside an apartment/condo or car port in Japan).
Maybe the aftermarket folks can make a fast gear for it?
