Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-29-2012, 10:37 PM
  #17911
You can always stick some ofna diff lock lube in your servo saver to make it stiffer. Also, if your m03 is not turning good, you will need to take out the dog bones and get cva's or ecs drives. The ecs drives are not legal yet though....
bertrandsv87 is offline
Old 11-29-2012, 11:11 PM
  #17912
R/C Tech Elite Member
monkeyracing's Avatar
Originally Posted by Tim K
Is that with the motor attached? take the motor out and spin the front wheels, 5 seconds or more is what you should be aiming for.
There are some minis that are just over the 10 second mark.
Wow! What am I doing wrong? I've always prided myself on having a very smooth drivetrain, but 10 seconds is a long time, unless you're really good at spinning the wheels very fast. I use ceramic bearings (in the trans gears) with a teensy spritz of silicone spray and very clean steel bearings everywhere else.
Originally Posted by jha07
I'm trying to find a better servo saver for my M03. Is the Kimbrough large a good fit? And is it better than the stock one?
Kimbrough is a much better servo saver than Tamiyas. You'll likely have to drill your own holes to get the exact length you're after, but they last forever.
monkeyracing is offline
Old 11-30-2012, 08:39 AM
  #17913
Core Creations's Avatar
Trader Rating: 108 (100%+)
Bearings have to be great in silver can racing..I actually prefer plain old metal shielded bearings and always get 10+ sec drive train freewheeling...and the rears go forever. It's all in the prep.
Core Creations is offline
Old 11-30-2012, 09:07 AM
  #17914
My rears can barely make 10 seconds. I think it's because the new bearings in there are packed with grease which slows them down.
jha07 is offline
  #17915
Posted a reply to your ball diff ????? on the previous page. Hope you saw it
Granpa is offline
Old 11-30-2012, 11:19 AM
  #17916
My bearings have always been good. Rear wheels will spin while I run out for a sandwich. Individual bearings spin very well by themselves after a good cleaning (I actually built a tool for the purpose) but when all is assembled, it certainly doesn't seem like a ten second proposition (there's a joke in there!) unless I spin it up with compressed air.
If anyone's got video of a complete drivetrain, minus motor, spinning for 10 seconds, I'd love to see it. It just doesn't seem like our trannys are built that accurately.
Old 11-30-2012, 09:01 PM
  #17917
I'd like to see that jig..
jjjheimer is offline
Old 11-30-2012, 10:51 PM
  #17918
Ask and ye shall receive. I took a cheap 12v gear/motor thing from Princess Auto and glued a bottle to it. I usually use 99% isopropyl as my cleaner. Remove the shields and chuck 'em in there for a while. After you remove them, get them dry and see if they spin freely. If they're good, a single drop of light oil will cover the lube requirements. I don't do this to the ceramics, though. I just run them as I get them. Avid uses a very good grease that breaks in very well and actually spins even better than a good, clean metal bearing.
+ YouTube Video
...or was this the kind of jig you meant?
+ YouTube Video
Old 12-01-2012, 09:43 AM
  #17919
Gary NJ's Avatar
I'm putting together an M03L and built the car using the 50746 CVA Super Mini shocks and the 53333 short tuned springs. I used the short ball end on the shock shaft and I have it screwed all the way on the shaft, but even with no spacers I can't get my ride height below 6-7mm. Am I missing something? This is for hi bite carpet, and I'm told I need to be able to get down closer to 4mm ride height. I hate the idea of trying to shorten the springs, but I cant think of what else to do.
Gary NJ is offline
Old 12-01-2012, 10:00 AM
  #17920
FauxMako's Avatar
Put spacers on the shaft inside the shock body to limit the full extension of the shock.
FauxMako is offline
Old 12-01-2012, 11:12 AM
  #17921
Trader Rating: 36 (100%+)
Are the racing gears for M03 & M05 a strong material, and or a different ratio too?
80'sracer is offline
Old 12-01-2012, 11:28 AM
  #17922
sosidge's Avatar
You should be able to get the ride height well under 6-7 mm unless you are using an unusally large diameter tyre. Do you have a picture?
Putting lots of spacers inside the shock will pre-load the spring a lot, it will make the car very edgy.
sosidge is offline
Old 12-01-2012, 11:29 AM
  #17923
sosidge's Avatar
When you say racing gears, which exact parts do you mean?
sosidge is offline
Old 12-01-2012, 11:46 AM
  #17924
Gary NJ's Avatar
This is with the kit tires and wheels. I did put the longer of the two spacers inside the shock, but I did that to limit droop. I would think adding more spacers would eliminate any droop and eventually preload the spring. Ride height would be lower, but I agree that isn't the way to fix it. I'll try and post some pics later, not by the car right now.
Gary NJ is offline
Old 12-01-2012, 12:16 PM
  #17925
These,
http://www.ebay.com/itm/3Racing-M05-...ht_1718wt_1091
