Tamiya mini cooper
I was talking about reusing the wheels. And him showing complete disrespect for my post about how I mount my wheels, and thinking I will just sit here and get stomped on, that is not going to happen.
Like I posted above, if you need to glue both sides, do it!! From my driving around on parking lots and my personal track, I don't need to. Why make a simple situation complex for the hobbiest that may not need to glue both sides? It's not like everyone reading this thread is all about competition.
I've free wheeled the tires off the ground and even at max speed, the tires do not bulge like it does on my TC cars. And even from actually driving the car, no issue of tires coming apart. Honestly I too was skeptical at first as the norm for me is to glue both sides, but not required for me.
As stated from the beginning, I am posting a different angle for the hobbiest who play with these cars at home for fun. You guys can talk about competition stuff all you want.
Just because we race, doesn't mean we have no clue about the hobbiest. Your more than welcome to do things your own way. But your now including yourself in a group discussion. Your way might not work, and in this case, can end someone's race (or bash session) really quickly.
Using one motor screw, can save you weight and makes it twice as quick to remove the motor which is great! It doesn't mean its a good idea to suggest it, and ruin gears. Gluing tires on both beads is the best advice always on all RC cars. Tamiya also glue both sides of the tires as supplied in there RTR mini kits.
Interesting affect the sakadachi has on this thread. Thanks.
I will be more careful next time. But I didn't suggest it, I just posted that's how I've been doing it on my m-chassis. I don't preach here, I just post how I do things. You are more than welcome to try it or not try it.
Let's keep an open mind. It's not like this hobby is growing much. We are a dying breed, we only got each other and the readers.
I'm with Aaron on this.
The cars I race with: tires glued on both sides.
The cars I bash with: tires glued on both sides.
The scaler I crawl with: beadlocks
Moral of the story: rubber security on a rotating assembly is always a good thing, no matter what your speed.
Ok guys well put on all ends. I appreciate all the information you guys have given but if something works for someone and doesn't for another that's ok. We're all here to discuss things and wow!... what a heated one this was lol. Personally I will glue both sides to be safe and thorough because I'm a little meticulous to be honest. Now Granpa. ...can I reuse the foam inserts to save a little coin right now. I'm just toying around in the street right now??
The cars I race: Glue both sides, do not reuse wheels.
The m-chassis I bash with: try gluing one side. if it works, reuse wheels.
CC01/CR01 I bash with: bead lock and screws (CR01).
While car is not used, I place chassis on a stand or box to elevate the tires off the ground to prevent flat spots.
Actually, I also have all my cars on stands. The exceptions are my Midnight Pumpkin and Clodbuster and vintage Bolink Legend (which is hanging on the wall in my shop). I do pull the tires off my offroad buggies to clean them and then place them in a container. Tires are usually still on my on-road cars when they go on their stands.
Sak, you must pull your wheels/tires off and place them in bags (vacuum sealing optional) to keep them out of the elements to keep 'em fresh.
Can you recommend me a nice stand for my M03, M05, and V2? I made a stand with 2 narrow sticks of balsa wood on its side glued to a box as the Tamiya's have an odd shape on the bottom.
My CF deck chassis, no issue as it's flat on the bottom.
I keed I keed....
No recommendations as I'm using homemade stands as well. Looks like we're in the same boat as I need to make some modifications to fit my Tamiya M-cars better.
Yeah, I put little handles on the side of the stands too so that I can pickup the chassis with the stand for convenience. I shall take pictures later for your reference, not a suggestion!
R/C Tech Elite Member
Mini Pringles cans are perfect for storing tires. Pieces of 2x4 are great for car stands. Tires are always glued, or in bead locks, with one exception. Last night I stretched a set of 1.55 Desert Kings onto 1.9 Tamiya Hummer wheels. They're not going anywhere!
It's got me wondering if I could stretch some S Grips onto TC wheels.
