Tamiya mini cooper
Anyone on here broken an M05 V2 chassis yet? mine did and there appears to be quite a few more on the M chassis facebook page.
Saw that Facebook post too. Maybe it's the speed from the 13T motors those guys run?
The actual overall ride height, within reason, seems to be less important than the variance between the front and rear ride heights. For example, if it's best to run your car with the same ride height front and rear, using whatever measuring criteria, a variance of 1mm either way will make less difference than a variance of 1mm at either end of the car.
Overall ride height is not very important to me beside getting the nice flush look on the arches with the tire sidewalls. I want max clearance under the chassis especially running parking lots. Not fun hitting the bottom of your chassis and slowing it down or bumping it messing up your line. I dont even use the ride height setting grub screws on the V2 to force it down.
Doin' some head scratchn' here. I've been away for awhile so could be horribly mistaken here, but aren't those for setting droop????? I don't have a v2 and am still using my "trusty" M03. It is a project that is in the planning stages( I'm acquiring the necessary components) so have tried to keep up. I don't see where ride height adjustment screws go.
Please excuse my ignorance, but as soon as I can get my hands on a kit, I'll be back up to speed. I've looked at a couple of v2 models and don't see the value of those screws. It seems like a needless complication and I understand a lot of guys have gone back to using overall shock length for droop.
And I agree with you, the droop screws are at least for me, useless. I have them installed on the car but haven't used them. My other chassis have them too, but I don't use them either.
The V2 is a completely different machine from the M03 and M05 so it should be fun to have the different flavor to play with. I think the V2 is easier to set up, and has much lower cog, but better or not at competitive levels really depends on the driver. Your long experience with M03 could prove V2 worthless, or take the V2 to a whole new level.
R/C Tech Elite Member
The thing with the droop screws is they're replacing the function of building dampers to a certain length. Building a short damper was effectively just limiting droop. At least this way, you get to build shocks full length and adjust on chassis. That's how I see it, as that's what i was using shock length for.
Anyway, I'd like to thank the global popularity of yoga for making so much foam so readily and cheaply available absolutely everywhere. I picked up this block of high density foam for almost nothing tonight. Fired up the foam cutter and have started building bumper blanks!
Pretty awesome what you can do with leftover stuff from the junk pile!
For those who are mistguided here, our 13T sensorless Hobbywing are not causing the chassis failure. Neither is it big crashes, although I can not say for certain. My chassis failed through the bottom of the chassis on both sides where the sprue attachment is. I cut with proper cutters and cleaned with a sharp hobby knife, however both sides split into the main bearing housing on both sides. This was on the chrome chassis.
At the mini nats, I witnessed a total failure of a black chassis also. I believe it because we run low ride heights and scrape the chassis which is already thin, which makes it more prone to failure. I also think the quality of Tamiya parts has changed since they have outsourced there production of parts.
From those pix, it certainly looks like the ride height (scraping the chassis on the ground) had
something to do with it. I'm just wondering if the additonal speed from the faster motor accelerated
the wear down process?
Hi Mini Racers,
I don't often post - just a lurker - but a few posts here lately have peaked my interest.
Saka: This left/right, on/off tracking is imperative to go fast. My eyeball measurements on the bench are never very good! I spend a lot of time in our track's staging area messing with the transmitter before even taking a lap. Left/right, throw, expo, servo speed if you've got it, use those adjustments. Once set for the tires and track, only little changes might be needed during the day. I cringe, and note who to avoid, when I see a Mini struggling to go straight!
Cal: Are you sure your chassis has never come into contact with bad chemicals? Brake cleaner instead of electric motor cleaner? Maybe goofy tire sauce? I've been racing Minis almost as long as Grandpa, and have never seen such a thing unless chemicals were involved. Of course, all my parts are so old, I haven't yet experienced "outsourced" parts.
So, now what about F/R hinge pin lower shock mounts? Orlando is our fastest Mini guy right now (except for Chuck, who is such a stud he misses mains just because he wants someone new to win) and I've seen it on his car. When I tried them, car handled like poo. What have you guys found?
I hope this foam is flexible enough to make a decent bumper. If not, I spotted some yoga "cylinders" made of the same stuff as pool noodles that will certainly be spring enough. This EVA foam has a huge advantage in that it sands and shapes very much like balsa wood. Easy to work with.
I have a M05, and even though it has oil shocks and the full Tamiya steering upgrade, it still digs its front end in when breaking on corners, breaks the rear end out and then digs in again when the tyres grip. Its not smooth at all when cornering. Can anyone give me a clue how to sort this one out. It used to be worse, the upgrades have helped, but it hasn't gone away completely. Could it be my driving style ? I'm a touring car driver ?
Thanks.
Thanks.
What type of track are you running on, Carpet, Cement etc...?
What springs are you running on your front and rear?
Type of tires???
We need more info on your current setup to help you
Type of tires???
Thanks.
Thanks.
The biggest problem is that the best way to control the front end from "digging" as you phrase it and I call from end roll, is to do that at the rear of the car. This is why many Mini set ups run rear roll bars and stiffer springs at the back cause this is how you keep the front end from rolling over on you. Many think that this stabilizes the rear, but what it actually does is that it controls the front end roll and keeps that from giving you erratic amounts of grip.
Okay, with the what happens part of the answer out of the way, we'll proceed to how you correct the situation. The standard answer used to be, run a rear roll bar and stiffer springs in back. The problem was that this only marginally fixed the situation, which resulted in a car that worked one week and did not the next. I'll finish in my next post cause I want to address something Craig---Laguna Bozo ---- brought up.
Thanks.
Thanks.
Also pushing out the rear wheels using spacers also help. I don't know which springs you are using, but stiffer on the front, softer on the rear (I think mine was currently setup using yellow front with red rear springs, front using stiffer damper oil). I have a front stabilizer on the car but the benefit was minuscule. GL, hope some of this gets you thinking and started for your application.
If you get the V2 chassis, I am pretty sure most of your issues will be resolved. M05 and V2 are night and day different, V2 being easier to control.
