Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 08-22-2015, 02:52 PM
  #25426
sakadachi's Avatar
Figured out how to make the M01 track straight including on/off throttle.
Extended arm on bell crank to give it that extra torque:
Angled to provide full lock:
Rear right droop screw (the suspension works like a seesaw so limited the height on right side to raise the left).
sakadachi is offline
Old 08-22-2015, 03:47 PM
  #25427
This is a question for those use the 3Racing Gear oil Diff. Can you buy replacement outdrives? I can't find any.
Mine have become heaps worn and its chewing up the plastic driveshaft caps.
Edit,
Found these. I think they are right.
http://www.rcmart.com/3racing-heavy-...h=595_744_1494
filippimini is offline
Old 08-22-2015, 03:55 PM
  #25428
c-lyon's Avatar
Yes, those.
c-lyon is offline
Old 08-22-2015, 04:31 PM
  #25429
R/C Tech Elite Member
monkeyracing's Avatar
Won't need to use blades with those ones, either.
monkeyracing is offline
Old 08-22-2015, 04:34 PM
  #25430
Awesome. I've put them in my cart.
Old 08-22-2015, 11:20 PM
  #25431
Hey guys, its been a while since I've run 55d tires. Back when I used to swap between 55d and 60d tires, I never really messed with building my shocks to a specific length. In fact, I probably built as per the manual, save for an o-ring under the piston and one on the shaft, below the shock body. What I'm wondering is if anyone running 55d tires builds to a specific length. If so, can I assume it's around 56-57mm, as opposed to the usual 54-55mm used when running 60d tires?
Jim
Old 08-23-2015, 03:54 AM
  #25432
Tim K's Avatar
Yep, you're bang on the money. I set mine to 56.5mm.
Tim K is offline
Old 08-23-2015, 05:08 AM
  #25433
sakadachi's Avatar
I don't. My M05 runs both tire sizes. No issue.
Gotta love the 55's. I wish there were more tires in this size
http://www.rctech.net/forum/members/...5-low-down.jpg
Old 08-23-2015, 09:19 AM
  #25434
(0000000000)'s Avatar
Not running s-grips anymore Jim?
(0000000000) is offline
Old 08-23-2015, 03:44 PM
  #25435
I'll be running S Grips at some point, like, when I've got money to buy some.. Just feel like playing with 55s for now, seeing as I have some. Edmonton decimated my last good 60s.
So, I did find a big difference in length between my old, bronze coloured TRF shocks and my newer 54000(?) shocks with replacement piston rods. The old ones measure 61mm end to end, the newer ones, 57mm. Same size shock bodies, different shafts.
I used to hate shock rebuild day, but ever since Bob told us about venting the shock cap, life has been a little easier. Thanks, Granpa!
Old 08-23-2015, 05:28 PM
  #25436
hprt's Avatar
The issue is ride height/ground clearance. From some of your earlier posts, it sounds like you run lots of ground clearance...
If you have run 60D tires normally, and you have your ride height set to the minimum - be it regulated by a race director or what works well at the track you run, when you switch to tires that are 2.5mm shorter in sidewall, then you need to extend the shock length to get the minimum ride height back. For practically all M chassis, you set the ride height using the threaded shock collars / spring length and set the droop using spacers in the shock to control or limit the overall shock length.
If you never run at minimum ride heights with proper droop for medium traction, then you probably never noticed this problem. for those of us that do, when you switch from 60D to 55D's, your chassis is scraping the ground. I normally only run about 3mm of ground clearance on my race minis, so taking away 2.5mm of clearance doesn't work.
hprt is offline
Old 08-23-2015, 05:30 PM
  #25437
sakadachi's Avatar
My other non-M01 cars besides my low riding M05 would scrape with 55's.
EDIT: No one wants a used Genetic?
http://www.rctech.net/forum/r-c-item...ller-only.html
Not for me, as I won't be able to mount the rear posts for the Tamiya Rover Mini body.
I should be getting my Sabre4WD Mini today or tomorrow. First thing I need to do is copy the rear body post hole locations from my SabreFD Mini and verify that I can drill 4 holes.
Old 08-24-2015, 09:54 AM
  #25438
Which servo would you run in m05 with V2 rear end with big bore shocks? im using spektrum DX2s radio set.
I currently got those servo
Savox 1251mg 0.09 @ 6v (dont like this servo, too glitchy, currently stripped gear)
Hitec 5645 servo 0.18 @ 6v sec servo
Futaba BLS352 0.15 @ 6 (currently fitted to my 4wd buggy)
I have the option to buy futaba S9550 low profile which is 0.09 @ 6v
So what spec servo is "too fast" for mini. (sudden change of directions which can cause loss of the grip, causing it to understeer)
Which servo I should run?
Vrooom is offline
Old 08-24-2015, 09:58 AM
  #25439
sakadachi's Avatar
I read your post while I was finishing up a meeting. Didn't realize you were asking which servo's to prevent understeer (not oversteer/twichy-ness) from too much speed.
Here is an edit..
I run 0.09sec/60 degrees full turn/return speed. No issue with under or over steer. I think you need to setup your car so that you have more rake in your case, reduce toe-out, stand your front dampers more (add damper stays), soften front suspension, add more offset in the front wheels, use less toe-in on the rear, etc.
Old 08-24-2015, 10:27 AM
  #25440
With the servos you mentioned, there shouldn't be an issue with being too fast that it induces understeer. If the car is too twitchy, then oversteer is the culprit and can be tuned to your comfort level of driving.
What is your current setup and track condition?
