Tamiya mini cooper
R/C Tech Elite Member
I guess HPI's bread fell butter side down.
The only part I've broken on my v2 (twice) isn't even v2 specific. I keep breaking the rear suspension plate. The v2 does look weak just under the battery/motor area, but I haven't seen one break yet and I crash lots. LOTS.
Monkeyracing - hahaha!!
got a question,
I noticed that our top racer was using a cooling fan on not only his esc but also the motor. He had it mounted off of the steering post nearest the motor, the fan sat diagonally above the end of the motor ..directed at the portion of the motor that protrudes from the chassis.
I figure that a cool motor will run stronger/faster, -right?
So, is it legal per TCS rules to run a fan on your motor? If so, I am guessing this would be good, yes? My motor temps are about 140-150 ...would I gain much from installing a fan on my motor as well? ...or would the extra 10grams of weight offset any reduction in motor temp?
I saw this and figured it could mount on the end of my motor:
http://www.integy.com/st_prod.html?p...w#.VXidNDBVhBc
thoughts?
thoughts?
macros- Looks good! Would you please post up a few pictures of your bumper and mount? Is that a custom mount you made? I wanted to get something like that for my V2 as well.
I've been using the 3Racing M05 cooling fan for a while, works well for me with my black can/nimh set-up, don't know what it would be like with brushless/lipo though.
i do like those CF fan mounts ...my temps are around 140degrees ...which isn't bad and my car feels strong/but if I can get it to run even cooler!
I may have to try this out ...
This is as it comes, #M05-04
Fits on in place of the original Tamiya C2 part.
I made my foam piece bigger in every way for more protection all round.
It definitely added life to my MINI Coupe shell, I got three indoor seasons and one outdoor season out of it before I retired it.
Hi,
Where do You guy's measure the front ride height becauce the chassi is not flat?
Claude
Claude
Yeah, I was looking at the bottom of your chassis and yes you did push the car pretty hard. That's a good thing, these cars are made to drive.
Thanks again.
When you think about it though, it's really unimportant in setting up your car as long as you measure yours the same way each time. From the different techniques for measuring, most are pretty inaccurate. Most of the time, the measurement at the front of the chassis is pretty suspect since most guys use a ride height gauge. Most of these cannot measure the ride height accurately on a Mini.
You will find that when the stated ride height is 5mm, it can be as little as 3mm or as much as 6-7mm. Unless you measure using the same technique, the same point, and the same make of ride height gauge, you will probably not duplicate a stated ride height.
The actual overall ride height, within reason, seems to be less important than the variance between the front and rear ride heights. For example, if it's best to run your car with the same ride height front and rear, using whatever measuring criteria, a variance of 1mm either way will make less difference than a variance of 1mm at either end of the car.
I put a piece of tape on the bottom of my chassis to keep dirt from getting in (along the bottom where the chassis halves come together). I can see if the chassis is too low if the tape is shredded or scuffed. Using this technique I've been able to keep my car as low as possible w/o it touching the ground and still getting good shock travel/rebound.
