Yokomo MR-4TC SD
How much droop are you running front and rear? How much rear toe? Where is it losing traction entering or exiting? Try running 2, 2.5, 3, degrees rear toe. try increasing rear droop. not enough info on your set up to really help.
also check if the rear suspension travel is smooth.....sometimes there's some binb on the suspension, and it really makes the rear suspension critical....
Originally Posted by todb
i just got a used rayspeed SD. Ran it on on carpet/rubber/stock. it was ok but the only problem was the rear end would come loose if i was not as smooth as possible which i did not like. it slowed me down to much. i have all rayspeed springs,pistons,oneway option, swaybars as well. i was just looking for some help to keep corner speed up without losing the rearend. thanks
Originally Posted by speedy-932
I just finished the drawings and will show them to the guy with the lathe on Thursday (I hope so... )... I hope I can find enough guys who want a spool and/or outdrives because then I will make them on a huge CNC centrum... Oh guys, that's fun... very precise but expensive... If I can find buyers for around 20 spools or 20 outdrives I will produce them there.
Gruß
Chris
Gruß
Chris
I forgot to say that. The outdrives and the spool are designed to work with the Xray blades. They work fine aswell. I don't have the Corally blades so I can't meassure them.
Cheers
Chris
Cheers
Chris
Corally blades are .118 of an inch -JB
Inch? What's that? We european guys only understand metric sizes...
I designed them to fit with the Xray blades for a few reasons:
1) Better part support
2) I think they are cheaper
3) I have the sizes for the blades here
But do you can make a picture where I can see a Corally blade installed on a Yokomo CVD? Perhaps they fit a bit better...
Cheers
Chris
Cheers
Chris
Cheers
Chris
Cheers
Chris
I would take some outdrives....Two sets one for the BD and one for the LCG....
Let us know when and how much as If I have to buy x ray cvds I will have to make that purchase at the same time.
Thanks,
-Shookie <><
Thanks,
-Shookie <><
Gruß
Chris
Gruß
Chris
looks like I found some info on the one-way shaft! but its in Japanese, can someone translate please?
Go here: http://chihuahua.pupu.jp/rc2/34.htm at the end of page
It may be available at rc-rainbow or is it rainbowten?
Could anyone tell me if shock towers from BD fit to SD? And if they fit is it good idea to use them in SD?
@Mr. Shookie: You won't have to buy new CVD's... just the small platic parts called blades... To imitate you...
http://www.speedtechrc.com/store/ebp...id=196&id=1924
I can tell you on Thursday how much they will cost...but still the same rule... the more you take the cheaper they will get...
Cheers
Chris
Cheers
Chris
Cheers
Chris
Cheers
Chris
