Yokomo MR-4TC SD
the Team Suzuki parts are top quality, the Speed Racing parts seemed "cheap" to me when I saw them
Is there a need for a 3mm bottom deck and top deck for the Yok LCG conversion? Or are most of you running low bite and find the stock chasssis a better fit for your racing? PLease leave some feedback if you think the LCG could be benefitted by a "carpet" chassis.
Ray
Ray
Ray- I think both the BD and the LCG could greatly benefit from a thicker "carpet" chassis. Both were designed for rubber tire asphalt racing and have a pretty flexible chassis. EA Motorsports is supposed to be working on a carpet chassis for the BD but no one that I know of is working on a commercially available carpet chassis for the LCG.
Does anyone know where I can find some blue cone washers on the net? I would like to use 2 on the top deck and for the shock towers?
Matt, Thanks! Do the drive cups handle mod motors motors? I did see Masami use some on the SDW at the worlds but just wondering...
Thanks again!
Thanks again!
Thanks again!
Thanks again!
My LCG had its maiden run today!!!! And it ran Beautiful!!!!!! RS Yellows and RS Blue atthe back made it better in any type of corner! Considering I used a Jetta body for our 4th Annual Wacky CUP!! (wacky race=you have to use non raceable body and everybody has the same body color!!! you can bid to be in the pole position and the pot will be used up for drinks for everybody and a BIG Roasted Pig on the Side for everybody=fun/fun/fun)
I guess it will only get bettr once i use my Stratus3 or Mazda6 body!!!
Ray: a stiffer or thicker chassis will be great!!!
It took me awhile to get my hands on those cone washers, got them at RT, i do not know the part number I just sent a picture which I got from rcsquare.
Thanks again!
Thanks again!
Carpet
Ray if you make the chassies please move the batta up one cell or add a xrta cell hole for mor batt adjustment.
First race with LCG
It ran great all raceday. I qualified fourth out of 21. Not too bad with the quality of racers in my class. The car worked great. I lost 1 spur and two sets of rear diff gears due to rocks. Shookie, LMK asap when you get those lexan covers for the diffs!!!!! I like how much quicker it transitions and gets into the corners over the SSG. It seems like a better spool car than the SSG. I haven't tried a one-way so I can't comment on that.
I got brutally hacked by a guy how bumped into the A and jumped (bashed) to 4th place by the first lap. He smacked the wall right in the middle of the straight and just flat out cleaned my clock. After about 3feet of air, I landed on the other 6 guys who proceeded to give me the ol' fieldgoal boot across the track. Cracked RX and shattered battery assembly. Nothing broke in the suspension, just scratched up alot of parts.
I'm going to give it a work out with modified next weekend. That will be the true test.
Guess which one is mine...
sorry to hear about your diffs, after six months with SDW i have finally broken one tooth off the output gear, ring gear is fine. sounds like you had a good time anyway.
Now that you have driven it you see what I was refering to when I said it handles like a belt with the rip of shaft...Great steering on the LCG...Just not really meant for parking lot or un managed tracks...
I will get my chance to prove the LCG is great on the 17th for the next round of the JBRL here in Southern Cali. I was fast with it last time I ran it so I will try it the way it is setup now and try a different setup with a spool and see what I prefer...What I really want to try is a oneway shaft and front diff combo... Well if and when Yokomo finally releases the shaft I can then. Hey Matt any word on this?
-Shookie <><
Also what is your setup.....I like to compare notes...
I have forgotten my setup since I haven't raced it in like three weeks....The KO Grand Prix was only 19T so No LCG just BD...Now I recommend everyone that lives anywhere near here to go next year...What a great race....Funnest time RC'ing ever.
