Yokomo MR-4TC SD
Is anyone working on an aftermarket LCG chassis & top plate specifically for high-grip/carpet racing?
I'll make the first few for myself, and if they work good, then I might sell a few chassis to my fellow LCG compadres.
Whoops should read before posting The number one rule to follow to avoid forum clutter
Anybody tried the speedtech front spool? I ordered one today for my SD. I'll give a review if I'm the guiena pig
Yes, we have tried the standard one and also the light weight one. Both are much better than Yokomo Plastic one !!
-Shookie <><
Hi,
nothing new on the outdrives and the spools yet. I think the guy I met today isn't the smartest... let's what the other one says...
Which setups do you run on your LCG's? My setup isn't that bad but I think there are a few guys out there who could wrench much better setups then me... Please post what you have... Carpet, asphalt,...
Cheers
Chris
Cheers
Chris
Guys, you might not remember but I posted a while ago about my rear diff gear wobbling.I still have this problem because I m waiting for a new set of outdrives and graphite gear from precisionrc and I was hoping that with these new parts my 'wobbling' issues will be solved..?
What do you think?
I received some carbide balls though, b\c I thought this could help but I dont know if I should try and rebuild my diff with them to see if it solves the problem..?I did rebuild the diff and checked the gear for flashings but no results
This wobbling isnt binding the drivetrain because I shimmed the diff gear away from the bevel gear otherwise they would be a hard spot when both gears got too close but the whole drivetrain is affected: center driveshaft and spur gear moving\wobbling side to side
I know this has been brought up before but any extra help\suggestions would be VERY appeciated!
What do you think?
Also, replace your inner diff bearings. It's possible one of them could be out of round. OR if your diff gear isn't sitting flush with the bearing due to impropoer molding. Then the gear would be untrue and wobble.
Originally Posted by speedy-932
Hi,
Cheers
Chris
Cheers
Chris
Cheers
Chris
Cheers
Chris
Thanks... I will search it...
I don't think it's possible to make some aluminium bevel gears and diff gears...
Ok... it's possible but really expensive... I'm not able to draw the gear with a CAD programm... the only way to get the sizes of it is to scan the gears in 3D with a laser... I don't know anyone who such a machine... I know a few companies who have one but they are in the development area... No way for me to get in there... I will look around if I can find someone and how much he wants but I think the price will be way too high... The price for a bevel and a diff gear will cost as much as a new car kit...
Cheers
Chris
Cheers
Chris
What would be really cool is to make some aluminium diff and bevel gears. With the LCG, it would be wicked awesome to have blue gears and never strip one out during a race I know I'd buy them no matter what the price is
I want a custom motor fan and mount that is made of Carbon Fiber for the BD and LCG....anyone know of a manufacturer let me know...that one in the UK is like $50.00 each...too much so please don't refer to them...
Thanks,
-Shookie <><
Man Shookie that neon green in your sig hurts my eyes; what the hell does it say ... -JB
