Yokomo MR-4TC SD
#6601
ah, by the way, i think i will be one of the first who would have his hands on the cgm conversion kit next monday or tuesday (thank you steve ), i can't wait and it's very good to hear that toso is fast at the snowbirds with it.....
#6602
Originally posted by taisantobi
no i'm sorry, i don't know anybody who has one.
but when you buy it, may you please say something about your experiences with it?
#6603
Originally posted by Kenneth Tan
May I know how heavy is the CGM at full running weight with bodyshell? The specs list show that it is 1580gm.
haven't weighed mine yet, but i'm sure its a lil heavier than the 'Black' version i previously ran.. Shouldn't be too much of a problem, with my SSG (which is a tas heavier, if not the same weight as the Black) had to actually add a few ASSOCIATED square ballasts to make weight at a race..
#6604
R/C Tech Elite Member
Originally posted by johnbull
Randman.
How do you get on with the delrin diffs on the Barracuda, running hot mod motors?
Regards
Joe from sunny Malta.
Randman.
Regards
#6605
Originally posted by alch
Interesting. Might have to give it a try!
I remember a similiar product being used for cleaning jewellery years ago!
How does it compare to a bearing blaster?
#6606
Originally posted by DOTMAN
I've used the bearing blaster and the Integy Sparkle thing. I was very disappointed with the bearing blaster. I didn't feel it directed the blast through bearings all that well. I did like Integy product though. I use mineral spirits to loosen the dirt and grease/oil and the waves that the cleaner generates work the dirt out of the bearing and into the bottom of the tray.
#6608
Originally posted by Horatio
Tell me - does this thing just vibrate? Or is there some sort of 'magic' ultra sound thing going on? It doesn't really matter, I'm just really curious.......
#6609
Originally posted by Randman
For 17 bucks, I dont think you're gonna get much magic
Where I come from, you'ld be amazed what you can get with 17 bucks
#6610
That parts cleaner is really just an ultra-sonic jewelry cleaner. You can find those at Wal-mart or bigger dept. stores It does vibrate, kinda like your Braun shaver or Sonicare toothbrush. You put your cleaner of choice into the tiny tub, put your bearings and let it rip for a few minutes. You will see dirt, if any, settle at the bottom. Magic, nah....
#6611
It just vibrates, but that helps push whatever fluid you're soaking the bearing in through the the sheilds and shakes dirt loose
When I practice before the start of the qualifying for stock class, I always use a super stock just so that my pals get worried about my pace!!! Same logic........
#6612
Thanks anyway
#6613
Yeah, get one of those and stick a Yokomo or LRP sticker and tell them it is a prototype.
#6614
How is the new plastic chassis setup compared to the carbon fibre? I`m racing on carpet with rubber tires
#6615
CGM conversion
So the conversion kit only comes with the tub, steering assembly, towers, braces, and a motor mount? Can someone pls. confirm this? Thanks.
