Yokomo MR-4TC SD
#8266
Originally posted by Lonestar
Your shocks shouldn't be limiting droop. The droop adjustments should only be performed through the btr screws in the arms... you should have longer shocks. If everything is properly set-up. measuring droop with or without shocks should make no difference... the good thing about unhooking shocks is that you can check for suspension freeness.
Later,
Paul
Later,
Paul
#8267
Porter- I think you will enjoy the CGM. It is basically an evolution of the double deck car. Like items mentioned above and I like the steering rack on it as well. The car is very consistant and still very simple to wrench on. Let me know when you get all set up and maybe Ken and I will be able to swing a trip to Topeka!
Jeff
Jeff
#8269
Jeff hopfuly I will be recieving everything sometime next week, so give me about two or three weeks and I should be good to go. Also wanted to know when is the Hutchfest race?
Yodace I didn't actually put the order in I just told him that I was going to most likely be ordering one this weekend, but I came across this deal, and now all I need is a speedo, wich I will most likely order from him so I don't hurt his feelings to bad. Oh and I need a power supply.
#8271
FL-Racer I ran the Tc3 for a long time. Chassis flex (warping) is a real problem with that car. A chassis is junk after 1 or 2 race days. I never ran the Pro 4 but a local racer has. The problems with that car are gears and chassis tweak. needless to say he dropped that car quick. Hope this helps.
#8272
A TC3 has won the National championship here for 5 years in a row. Four of those have been the same car with the same chassis, and it's still the quickest, most relaible and best handling car here.
TC3s are still winning more races everywhere in the World than any other car, even though the car is now 5 years old.
You say you ran a TC3 for a long time. Then you say "a chassis is junk after 1 or 2 races". You must have been through an aweful lot of chassis.
Perhaps I misunderstood you!
Regards
Joe from sunny Malta.
#8273
Yippee!!!
I've finally figured out my front ride height problem...
Since installing a rear shock tower on the front of my car i haven't been able to get the front ride height below 6.5 mm.
I've been wringing my hands over this issue since last Saturday, when my car ran like crap!
Last night, with Masami and Tosolini's setup sheets in hand I finally discovered what I was missing. I needed to move the small kingpin spacer from above the steering block, to the bottom of the steering block.
It's a small, easy to miss adjustment listed on the setup sheet, but it makes a significant difference in setup!
#8274
Originally posted by johnbull
What are you talking about.
Regards
Regards
#8276
Gear Ratio suggestion
I just brought a Venno Fireball 17T modify Motor today.
It is a 17T turn motor, what driving ratio I should use guys?
any suggestion?
any suggestion?
#8278
Which is harder? the SD-CGM or TC3 grahite tub??
#8280
Re: Gear Ratio suggestion
any suggestion?
any suggestion?
More conventionnally: on tighter indoor tracks, I gear mine from 5.7 to 6.4.
Modern 17T (Orion Orbitals, Corally) are VERY rewarding... they're fast, and wear out slow: you easily get 10 runs out of Q-brushes with no special motor tuning.
Later
Paul
