Xray T2'007
Old 12-14-2006, 10:08 AM
  #1201
sukh's Avatar
It Depends on what motor you run, Komodo’s like a low roll out so 29-34 should work, dynasty’s and quad mags and those types of motors that you can gear to the moon you will need higher teeth pinions 34-40, I would get a set from 29 to 40 that way your covered.
sukh is offline
Old 12-14-2006, 10:31 AM
  #1202
Trader Rating: 26 (100%+)
I will be running a Cobalt 27 from Putnam. I ran some gear ratio charts w/1.7 transmission ratio & 114 spur. What final gear ratio range is a good starting point. Don't want to purchase 10 pinions and only need 3 to 4.
svines1972 is offline
Old 12-14-2006, 02:30 PM
  #1203
duckman996's Avatar
Trader Rating: 14 (100%+)
Originally Posted by svines1972
T2 007 EU running stock & 19 turn, switching to 64 pitch, Have a 114 spur. What would be a good range of pinion gears?
Foam or rubber tires? For foam you may need a few more then with rubber since the diameter of a rubber tire never really changes.
duckman996 is offline
Old 12-14-2006, 02:38 PM
  #1204
Rubber for now.
Old 12-14-2006, 03:11 PM
  #1205
JimmyMac's Avatar
I know the US has 30wt. What wt oil does the EU come with?
JimmyMac is offline
Old 12-14-2006, 03:15 PM
  #1206
Anthony.L's Avatar
Trader Rating: 41 (100%+)
All Xray touring cars come with 30wt, it's the only wt oil you need.
Anthony.L is offline
Old 12-15-2006, 05:12 AM
  #1207
Hi all,
I'm proud to present you our new products for all XRAY drivers. A new spool and diff out drives from "Pat Jasmin Products".
Here are pics of them on www.rcinfos.com (http://www.rcinfos.com/2006/2006_12_...ined_parts.php)
Our spools has been tested by several drivers and the results are very very good adjustement in the car and no wear. The spool and the diff outdrives are made in aluminium with high quality delrin outdrives.
I use the diff for the first time at the GP World Carpet Cup in Switzerland and all I can say is that this parts is really very good.
The particularity of these parts is that we don't use blades anymore so it is very economic.
For more information (pricing,shipping...), you can PM.
All feedback or comments will be appreciated as we always want to improve our products.
canto54 is offline
Old 12-15-2006, 09:11 AM
  #1208
Does 114/33 - 5.87 ratio sound like a good starting point for gearing? Rubber/Carpet/CO27
Old 12-15-2006, 09:16 AM
  #1209
SlamMan's Avatar
Yes.
SlamMan is offline
Old 12-15-2006, 09:40 AM
  #1210
Old 12-15-2006, 11:34 PM
  #1211
big_boss's Avatar
Originally Posted by canto54
Hi all,
Where does one buy them?
big_boss is offline
Old 12-16-2006, 03:27 AM
  #1212
Big_boss, PM answered
I will take some pics of the diff on my car this weekend. This diff is a really strong. I run it all the GP World Cup in Swizerland and na wear at all after 20packs in mod with it.
We also make a spool to be used with tamiya CVD's.
canto54 is offline
Old 12-16-2006, 08:10 PM
  #1213
adamge's Avatar
Hey all. I'm new, so I'm just using the pros' posted setups. I'm running Mod and Stock on a small carpet/foam track. Right now I'm very happy with Barry Baker's Cleveland Mod setup, and Travis S's Stock IIC setup. If anyone else is in a similar situation, I recommend trying these setups.
adamge is offline
Old 12-16-2006, 08:41 PM
  #1214
SlamMan's Avatar
I didn't see this posted anywhere so here it is.
T2 Center one way.
http://www.teamxray.com/teamxray/new...kategoria=738&
SlamMan is offline
Old 12-16-2006, 08:55 PM
  #1215
Trader Rating: 17 (100%+)
Very similar results, I've been running Travis's setup and its dialed!
Kave is offline
