Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 10-26-2009, 10:00 AM
  #11251
Rick Hohwart's Avatar
Originally Posted by S_fender
Question for Juho Levanen,
Could you, please, publish your ETS setup ?
Thank you.
Sébastien.
Originally Posted by bfong13
+1
Juho ran the same setup as his 2009 Reedy Race setup.
Rick Hohwart is offline
Old 10-26-2009, 01:45 PM
  #11252
LOSI123's Avatar
Trader Rating: 63 (100%+)
Does anyone make or have in stock some dust cover stickers for the tc5 diff?
LOSI123 is offline
Old 10-26-2009, 01:57 PM
  #11253
Trader Rating: 38 (100%+)
TOP Racing does. The TC5 diff seems to stay relatively clean without them. I have some of the TOP racing diff stickers but haven't tried them yet because I haven't really needed them.
or8ital is offline
Old 10-26-2009, 02:28 PM
  #11254
S_fender's Avatar
Wow it's good to see that the same setup works on different track layout.
Thank you for the answer Rick.
S_fender is offline
Old 10-26-2009, 03:51 PM
  #11255
LOSI123's Avatar
thanks,
Also how does the slipper spool hold up? does it come loose when running more powerfull motors?
LOSI123 is offline
Old 10-26-2009, 05:41 PM
  #11256
thanks,
Stock it came loose for me with a stock motor. Used the TC3 diff screw and nut with plenty of loctite and it has held fine for me.
or8ital is offline
Old 10-28-2009, 01:51 AM
  #11257
Is anyone changing out the steel axles/dogbones for lighter ones?, has anyone noticed it being faster to use lightweight / aluminum dogbones and axles from other manufacturers, have you noticed it being faster due to less rotating mass?
MoonTrap is offline
Old 10-28-2009, 02:16 AM
  #11258
S_fender's Avatar
Hello,
I use titanium racing CVD. Good products only 3g (But don't buy the layshaft).
But I did not measure the gain for a run.
Sébastien
S_fender is offline
  #11259
I tried some Ti ones. They were about half the weight. The quality on them sucked and I ended up breaking one of them very easily. Not to mention they were very expensive. I didn't really notice any difference.
or8ital is offline
Old 10-28-2009, 02:18 AM
  #11260
Hello,
Sébastien
Funny, I thought the layshaft was fine and the CVDs were garbage. Why do you say don't buy the layshaft?
or8ital is offline
Old 10-28-2009, 02:22 AM
  #11261
S_fender's Avatar
Yes funny
I've never broken any CVD and i use it since one year now.
A friend have the layshaft and have to much play. They use o-ring for the play and i don't like this.
Sebastien.
S_fender is offline
Old 10-28-2009, 06:47 AM
  #11262
Suspended
TiRacing has a deal on at the moment
buy one set of driveshafts get another free.
Happy days
Nick Priest is offline
Old 10-28-2009, 06:58 AM
  #11263
Warren Weaver's Avatar
Trader Rating: 49 (100%+)
I received mine and they are awesome i ran them in the tc3 and they never needed rebuilds and the angles are better atleast 3 degrees more throw and they dont bind up.
Warren Weaver is offline
Old 10-28-2009, 07:07 AM
  #11264
Yes funny
Sebastien.
Yeah broke one on a light hit, it broke inside the rear hub between the bearings. One that I received was also out of round and wouldn't fit in the bearing (not the one I broke). I had to take a dremel to it for a while to be able to get it to fit. These were both the worlds CVDs. The stealth so far have been fine and I've been using them on the front because they have a larger angle than the stock or the Worlds CVDs.
Yeah the o-rings on the layshaft seems dumb. I threw them out and used aluminum shims to space it.
or8ital is offline
Old 10-29-2009, 04:38 AM
  #11265
Default :)
Found this in internet
Pics from blog:
http://jdracing.blogs.se/2007/5/
Juho's car:
http://data4.blog.de/media/895/1472895_7b1d8c2bca_l.jpg
http://data4.blog.de/media/896/1472896_9290576640_o.jpg
Look to the Craig’s car:
http://data1.blog.de/media/003/1424003_7e7a917c26_o.jpg
Hm, which one steering linkage was better ??? Anybody know?
Regars!
m
M.Abramowicz is offline
