Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 03-12-2008, 05:02 PM
  #5506
beta bob's Avatar
Trader Rating: 2 (75%+)
Getpip,
you can try plumbers tape around the threads that usually works great.
beta bob is offline
Old 03-12-2008, 05:28 PM
  #5507
Trader Rating: 17 (100%+)
For Stock gearing on my TC5 I use 96teeth 64pitch Spur with a 45 or 46 pinion. Ths will give me a 4.2 or 4.1 gear ratio. I use a Novak 13.5 Brushless motor.
DJGonzo69 is offline
Old 03-13-2008, 07:16 AM
  #5508
Hello . I need help to setup the car for run foam tires on asphalt ( I know nobody do this ) So, should I try with stock setup ? any advices will be VERY appreciated.
People usually run with 35 or 37 GRP tires with success but noone has TC5
Thank you
cochecito is offline
Old 03-13-2008, 02:00 PM
  #5509
Victory Side's Avatar
anyone running brushless and have stepped up there gearing to use the Kimbrough 90T, 93T, or 96T 48p spurs?
We run several TC5's at our track. Our layout is 90x60 with 90 straight. We run a tight course in the middle. I run a LRP TC with 13.5ss. I use precision spur 116 with precision pinion 45t. Hope this helps. Its easy finding your role out since the tranny is 2.0 I love that about TC5.
I freaking love my car, upgrade bearings are awesome!!!
Victory Side is offline
Old 03-13-2008, 02:30 PM
  #5510
fathead's Avatar
Thank you
We run foam/asphalt here all the time, I can give you a setup so you are not alone!
Stock setup is rubbish for foam/asphalt
fathead is offline
Old 03-13-2008, 02:48 PM
  #5511
can you post it please ? I´m completely lost ¡¡¡
Old 03-13-2008, 03:49 PM
  #5512
Jsaves's Avatar
The TC5 can handle more speed so I am looking at what I can do to get faster. The car handles great so I am wondering what I can do to go faster. I am already not hitting the boards.
So I am running 19t foam on carpet.
Are you guys using the brakes on all corners, just tight ones or use them at all?
Thanks and God Bless
Jsaves is offline
Old 03-13-2008, 05:12 PM
  #5513
fathead's Avatar
Here is a link to 1 setup http://www.rcracer.com.au/forum/view...=asc&start=260 at bottom of page.
It is for a low grip track, 14sec laptimes.
I have another slightly different setup for my home track, medium grip, 20sec laptimes, but I don't have it uploaded yet.
fathead is offline
Old 03-13-2008, 05:16 PM
  #5514
thank you very much, I´ll give it a try
Old 03-14-2008, 02:39 PM
  #5515
Have a few questions for those running the new hard front suspension arms on their TC5. I ordered two sets and all 4 arms don't rotate on the inner hinge pin like the stock arms did???
Do I need to use an arm reamer to make them rotate better? Or is there another trick as I don't have an arm reamer?
Thanks in advance for any help.
Eric
748eric is offline
Old 03-14-2008, 03:44 PM
  #5516
SammyZ's Avatar
Trader Rating: 138 (100%+)
Eric
The solution to this problem is getting a cyclone
SammyZ is offline
Old 03-14-2008, 08:13 PM
  #5517
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Eric
Unfortunately yes. I had to buy the Hudy 3.0mm reamer to get mine to work correctly.
Kraig is offline
Old 03-15-2008, 09:31 AM
  #5518
Gain Time's Avatar
I am running the Novak GTB brushless system with a 13.5 however our track wants to start using the 17.5 in the stock class so I am getting ready to convert over. First I am having problems finding gears. Second I ran into a problem when I was trying to gear for the 13.5. I kept buying Pinions and spurs only to find out they wouldnt mesh with the Motor mount.
I would like to find out what gears fit the car but get the FDR to 3.5 and where do you get them? The closest I got was 64P 88/47 and that is 3.74. This was at both Stormer and Tower. LHS carries the motor but do not stock huge Pinions and do not know where to find them.
I am lost in finding the huge pinions or tiny spurs and in order to eliminate buying a bunch of gears I can never use can someone help me out?
thanks.
Gain Time is offline
Old 03-15-2008, 11:14 AM
  #5519
t4mania's Avatar
Try these pinions:
http://www.precisionracingsystems.com/products/7
t4mania is offline
Old 03-15-2008, 07:35 PM
  #5520
yyhayyim's Avatar
Trader Rating: 26 (100%+)
my buddy's running a TC5 tomorrow but the kit came with the wrong rear hubs...he might have to use other hubs from Xray, HB Cyclone, Losi, etc...any hubs from other cars that will work well with TC5?
yyhayyim is offline
