Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 04-03-2008, 09:01 PM
  #5656
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
+1 for the Boca bearings. I prefer to use the Green Seals just because there is no maintenance.
rezenclowd3 is offline
Old 04-04-2008, 02:26 PM
  #5657
LOW ET's Avatar
Trader Rating: 109 (100%+)
what's the benifit of using the aluminum diff over the stock one?
LOW ET is offline
Old 04-04-2008, 02:28 PM
  #5658
Sean Powers's Avatar
aluminum is stronger and holds up better
Sean Powers is offline
Old 04-04-2008, 02:35 PM
  #5659
LOW ET's Avatar
well i understand that much but is there a performance advantage or is it more of a reliability thing?
LOW ET is offline
Old 04-04-2008, 02:48 PM
  #5660
performance is better in the fact that it's more consistent. The plastic outdrives can melt under stress.
DOTMAN is offline
Old 04-04-2008, 02:53 PM
  #5661
LOW ET's Avatar
that's the info i'm looking for, thanks
LOW ET is offline
Old 04-04-2008, 06:08 PM
  #5662
robk's Avatar
Trader Rating: 22 (100%+)
The aluminum diffs are sweet, but i will say my plastic diffs held up for like 3 months straight. I only took them out because I put the aluminum ones in.
Seriously, they are excellent. No problems, ever. All foam tire racing too.
robk is offline
Old 04-04-2008, 07:19 PM
  #5663
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Just make sure that you run the plastic ones a little tighter especially if you are running anything hotter than a stock motor. If you run them loose you will slip a diff ring and this is what causes them to melt. You could always glue the rings to the plastic pieces but only if you don't like to run a tight diff.
For me, the plastic help up fine until I decided to see how loose I could run the diff with a 10.5. Needless to say I burned it up.
Kraig is offline
Old 04-04-2008, 09:48 PM
  #5664
Originally Posted by Verndog
Actually when I bought my outdrives I got NO T nut. I have 3 sets and none came with them. The stock ones work fine, just pickup new nuts to press inside and you'll be good to go.
The problem is that the plastic housing (with wide ears) that holds the nut will crack is over tightened (it doesn't take much). The only way to get a replacement part is to buy the entire aluminum diff outdrive. I have two sets of aluminum outdrives sitting in my toolbox that are now useless.
Pete
Pete Thomas is offline
Old 04-04-2008, 11:12 PM
  #5665
Verndog's Avatar
Trader Rating: 16 (100%+)
Pete
Pete..Like I posted...the stock plastic nut retainers work fine in the aluminum diffs. cost $4.95. I've not cracked or broke any, I just replace every couple of rebuilds for good measure. Yes, there is play between the plastic "ears" and the aluminum outdrive blade slots, but that wont matter once they are tightened. Come see me at SIR and I'll put one together for you. I get 40+ runs with them no prob.
Verndog is offline
Old 04-05-2008, 01:57 AM
  #5666
If you donīt use aluminium outdrives and set the diff a bit loose you can realize THIS:
cochecito is offline
Old 04-05-2008, 09:02 AM
  #5667
Zootcapri's Avatar
A....errr.... I have done that ... I believe you now have a poor man's spool
Zootcapri is offline
Old 04-05-2008, 09:03 AM
  #5668
Zootcapri's Avatar
In the beginning I melted two sets... then I got the settings right and have had no problem with the composite outdrives (and I bought the aluminum outdrives too... just never had to use them when I 'got it right').
Old 04-05-2008, 11:01 AM
  #5669
Poor manīs spool JA JA JA JA
very very good. Now I have one, je je je
Old 04-06-2008, 06:21 AM
  #5670
Gain Time's Avatar
RobK's post on the set up they were using for the Novak races shows that they used Losi 56 and 57 pistons in the shocks......I really dont want to buy anything from horizon so which of the AE shock pistons is the closest to those. I tried it with the #3 and the car handled very well although it was still pushing in the high speed sweepers which caused my car to be a little slower than the Xrays who seem to hold the line better. All the tight corners the car was right there so I think I could be faster if I could hold the line in those sweeping turns. I think maybe I need to be a little closer on the pistons and see if that doesnt fix it.
Gain Time is offline
