Team Associated TC5
#5671
Need rookie setup help...........
Here's my story. Purchased a TC5 a few months back and thought I would run rubber tire as it was a new class at my local track. We'll after about 6 weeks or so the rubber tire thing hasn't picked up and I couldn't for the life of me get my TC5 to handle, dispite may hours of tinkering. The biggest issue is my local carpet track is 95% Corally Phi's. So I'm basically the only TC5.
So I decided that the Foam class would be a bit easier to drive? Can anyone recommend a Rookie carpet foam setup for my TC5? I saw Robk's post, should I just follow that?
#5672
RobK's post on the set up they were using for the Novak races shows that they used Losi 56 and 57 pistons in the shocks......I really dont want to buy anything from horizon so which of the AE shock pistons is the closest to those. I tried it with the #3 and the car handled very well although it was still pushing in the high speed sweepers which caused my car to be a little slower than the Xrays who seem to hold the line better. All the tight corners the car was right there so I think I could be faster if I could hold the line in those sweeping turns. I think maybe I need to be a little closer on the pistons and see if that doesnt fix it.
#5673
I recommend trying the Juho/Hebert setup from Snowbirds that is posted on rc10.com...should be a good starting point.
#5674
Robks setup would be a good one to try....
Thanks for the advice. After looking at the Juho/Hebert I noticed they have camber set at -3.5 and -2.5. Does that seem real aggressive and will that cause extreame tire wear?
I basically brand new to this and want something that will offer stable handeling while I learn the ropes.
Thanks for any advice.
Eric
Eric
#5675
The Losi #57 pistons are close to the AE #3 and the Losi #56 are close to AE #2. You don't have to buy from Horzion...try Losi and Associated Parts House. They have good prices and cheap shipping --> http://www.losipartshouse.com/
Thank you. I will try the AE pistons first since I already have them and will only have to change one set at this point. If I am still just a little off I will try the losi parts. Thanks again.
#5676
Eric
Eric
#5677
Eric
Eric
The set up posted by robk is by far the nicest set up I have seen so far and may also be a good one to start with. Not too agressive but easily holds the line. You could tune the agressiveness with the amount of tire sauce on the front tires.
#5679
Eric
Eric
One thing you might try however for stock and super stock is gold rear springs. I ran our regionals this weekend and that really helped with rotation.
#5681
Yeah it took me quite awhile to find it myself so I copied and saved it in word. Here is the version I saved. The bold is what I copied from RobK's post.
Front
ride ht 4.5mm
camber -1.5
caster 6*
toe 0
hex spacing .5mm
wheel base 1mm shim in front
steering link 1A
bumpsteer 4mm
diff ball-cam a setting 1
tire jaco dbl pink 55.8mm
1/2 (13.5)to 3/4 (10.5)dope
shock
57 losi piston
60wt oil
purple spring
full rebound
shock 2a
camber link 4
stock ballstud
arm mount 2A ff/fr
shims 3* ff/fr
droop 1.5mm
silver swaybar
hard arms & caster block
ReaR
ride height 4.5
camber 2.0
toe hub 1.0, 2* overall toe (this is an aggressive setting, .5 or 0 toe at the hub mellows the car out/reduces rotation, when overall toe is the same)
hex spacing 0
wheelbase full long
diff ball cam a setting 8
tire Jaco dbl pink 55.8 full dope
shock
Losi 56
30 wt oil
full rebound
gold spring
shock 3A
camber link 5B (I like this a lot as the car is a bit easier to drive. 5A would be very twitchy on hi bite)
black ballstud w/2mm spacer
arm mount 1b fr/rr
shim 2*fr/3*rr
droop 1.5mm
no roll bar
hard arms
I was a couple changes away that made the car better for me.
Foremost was the steering link at 2B. 1A was hard for me to hold on to(very reactive), and I felt like i wanted a bit more overall steering. The 2 position on the bellcrank mellows the car out, and B tends to have a bit more steering all the way thru the turn.
I also went one hole in on the rear shock tower, which made the car rotate a bit more. My car seemed to touch the chassis edges a lot at the rear (even before I moved the shock), so i ran the black sway bar at the rear to help this. The other guys' cars didn't seem to be touching. That may have been my shock building coming into play.
#5682
Thanks guys for the rookie help. Believe me I need it.
So at this point I am attempting to put together my setup based on the Juho setup.
A few questions though.
What does hex spacing mean? Is this just a spacer between the hex nut and the rim?
Also under toe it says "2 in + 1 out"?? What?
#5683
