Team Associated B6 & B6D thread >
Like Tree649Likes
    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Old 07-08-2016, 05:36 AM
  #1216
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Johnn27
I think it would be better on a bumpier outdoor track because you will have more shock travel ??? Just a thought ....
Travel is the same for the two shocks, they both use 27.5mm shafts.
Jmuck69 is offline
Old 07-08-2016, 06:11 AM
  #1217
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
Correct. You benefit from the larger volume of oil in the longer bodies.
Matt Trimmings is offline
Old 07-08-2016, 06:37 AM
  #1218
Originally Posted by Socket
BTW, the B6 is in stock at Tower.
Would be nice if they extend the e-cash promo like they did in December. Christmas in July!
Off by a day. I wonder if it really ships or at least processed payments yesterday for those that back-ordered and they got the e-cash as that July 11 date might be in the way.
190mph is offline
Old 07-08-2016, 07:22 AM
  #1219
suby723's Avatar
Trader Rating: 21 (100%+)
Damn Amain is showing August 1st now.. Not even cool
suby723 is offline
Old 07-08-2016, 07:39 AM
  #1220
Glad I got my 6 coming.
Old 07-08-2016, 07:47 AM
  #1221
suby723's Avatar
I will just have to hold Ryan cav hostage for my b6 lmao jk jk! I am seriously impatient when it comes to waiting for my new car to arrive!
suby723 is offline
Old 07-08-2016, 08:03 AM
  #1222
Trader Rating: 17 (100%+)
Smile
I just went on amain and bought each part individually and chose overnight shipping. It cost me $1,287.73, but hey, I'll be first!!!!!!!!!
MrLean is offline
Old 07-08-2016, 08:06 AM
  #1223
celt's Avatar
I wouldn't pay any attention to that date. You'll have it long before that.
celt is offline
Old 07-08-2016, 08:24 AM
  #1224
Trader Rating: 68 (100%+)
Does anyone know what are the problems with the manual
Speedychris22 is offline
Old 07-08-2016, 08:32 AM
  #1225
The bottom where Kody talks about shock eyelets is one of the issues I know of.
Old 07-08-2016, 08:36 AM
  #1226
I ordered my b6 from tower on May 1st and it hasn't shipped or processed yet.
dsms4ever is offline
Old 07-08-2016, 09:17 AM
  #1227
celt's Avatar
I was just told by Tower that items are in stock but can't be shipped until Monday, due to "an agreement with the manufacturer."
Must be the deal that Matt was talking about.
celt is offline
Old 07-08-2016, 09:29 AM
  #1228
suby723's Avatar
If you watch Jason ruona's video at Amain hobbies he just mentioned that Amain is apparently recieving the b6's today.
suby723 is offline
Old 07-08-2016, 09:31 AM
  #1229
Finalist's Avatar
I think I asked this pages ago, but what is that benefit of more oil at the top exactly?
Finalist is offline
Old 07-08-2016, 09:34 AM
  #1230
Finalist's Avatar
there is another minor issue, but I can't remember it. It's on FB. It was't a big deal IIRC.
Also, they are recommending to NOT use 2 Ti screws on the steering rack for plastic and aluminum racks.
edit:
the other small error has to do with the bag 5-8 step 3 hat bushings. wording and picture are opposites.
Finalist is offline
