Team Associated B6 & B6D thread >
Like Tree649Likes
    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Old 11-09-2016, 10:35 AM
  #4276
BigChris in PA's Avatar
Originally Posted by Wildcat1971
While the B5 cups have "less" slop, the slop in the b6 cups is very minimal. My car has more than 3 hours of use and has almost no slop.
You must perform less unintended aerial acrobatics than I do. Some of mine are truly a sight to see.
BigChris in PA is offline
Old 11-09-2016, 11:19 AM
  #4277
BLKXJ96's Avatar
Is anyone having issues bending the rear aluminum ball stud mount? I have managed to twist three so far, at $15 dollars a pop this is getting pretty old. Most of the time the car will start to act real erratic and I bend it back but after a few times doing this it is too twisted to save.
No major crashes just normal bumps and bangs during racing or practice
BLKXJ96 is offline
Old 11-09-2016, 12:11 PM
  #4278
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
I've not personally bent one, but others have reported the issue. Get the Exotek one next time.
CCristo is offline
Old 11-09-2016, 01:21 PM
  #4279
Mason's Avatar
I will be putting this on my list.
Mason is offline
Old 11-09-2016, 01:34 PM
  #4280
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
New from Avid.
http://www.avidrc.com/product/5/acce...cessories.html
Wildcat1971 is offline
Old 11-09-2016, 02:03 PM
  #4281
Pinkz's Avatar
anyone know which TLR aluminum dogbones will work on the B6D? i saw a post awhile back somewhere, can't find it
also saw a photo of a battery brace for B6D that where you remove waterfall and run a link from gearbox to top of battery plate. anyone know who makes it for sale? maybe just a one off custom?
Pinkz is offline
Old 11-09-2016, 04:22 PM
  #4282
tschenck's Avatar
Trader Rating: 110 (100%+)
Nice they finally released it. Never bent one but I like that the rear end would all stay in place when you go to pull the gearbox.
tschenck is offline
Old 11-09-2016, 05:32 PM
  #4283
BLKXJ96's Avatar
Cool, Thanks man.
BLKXJ96 is offline
Old 11-09-2016, 07:09 PM
  #4284
RCBuddha's Avatar
Trader Rating: 40 (100%+)
http://www.redrc.net/2016/11/avid-b6...battery-brace/
http://www.redrc.net/2016/11/jconcep...steering-arms/
http://www.redrc.net/2016/11/jconcep...t-spring-cups/
RCBuddha is offline
Old 11-09-2016, 07:35 PM
  #4285
RCBuddha's Avatar
not sure if anyone saw these:
http://www.exotekracing.com/b6-front...1-pair-b6-b6d/
http://www.exotekracing.com/b6-hd-pu...-puck-systems/
RCBuddha is offline
Old 11-10-2016, 08:50 AM
  #4286
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
with all these aftermarket towers you darn near could have a shootout to see whose is the strongest.
I wonder if AE may do a revision since it seems like a popular item for aftermarket replacement, at least, for what we see being made.
Cain is offline
Old 11-10-2016, 08:52 AM
  #4287
rvrslt1's Avatar
Trader Rating: 35 (100%+)
So what motor is better for the B6D with lay down on clay 17.5 Reedy or the 17.5SS Reedy?
rvrslt1 is offline
Old 11-10-2016, 08:59 AM
  #4288
Everyone is making tower, because CF is easy to design and make. Molded plastic is much harder and expensive. As far as durability? They all seem to be the same. I dont think any tower on the market is clearly more durable. Aside from maybe the VRP tower. I just refuse to put aluminum towers on my car....
Old 11-10-2016, 09:08 AM
  #4289
duplicate
Old 11-10-2016, 09:14 AM
  #4290
Pinkz's Avatar
found it ....Puffy Panda's B6 Battery Brace
http://www.hobbyaction.net/products/...battery-brace#
freezeframe007 likes this.
Pinkz is offline
