Team Associated B6 & B6D thread
#3526
I'll tell you what radio and electronics I'm using in my B6D.
Castle Sidewinder 4600kv brushless system, switched the red and white wires so that the motor runs in reverse for a mid motor car and it works fine this way.
84 tooth spur does fit so I used that instead of the included spur gears. 19 tooth pinion.
Gear cover does fit with the 84 tooth spur gear on it.
Savox metal geared servo, Futaba FASST receiver so I can use my 3PM radio.
Battery I'm using is a stick pack. Common Sense Lipo 7600mah. 75C
I know I don't have the greatest stuff I can use but its going to work out for me.
#3527
You shouldn't have had to reverse the wires for the motor to work, any regular rotation motor works on the b6. Sounds like you may have something else going on like maybe it is reversed on your radio?
Did you calibrate your esc and radio correctly?
#3528
anyone?
#3529
Long eyelet if mounting the shocks to the rear, short eyelet if mounting on the front of the tower.
Unless you use the new schelle rear tower, it is designed to use the short eyelets even if shocks are mounted to the rear.
#3530
[QUOTE=xyzracer;14689756]You shouldn't have had to reverse the wires for the motor to work, any regular rotation motor works on the b6. Sounds like you may have something else going on like maybe it is reversed on your radio?
+1
I am using a hobbyking v3.1 stock spec and a reedy 17.5 and the motor runs normal direction. I gave up on castle esc due to weak becs.
+1
#3531
As far as the tower breaking, locally I've seen several stock ae and aftermarket carbon towers break. Pretty much everyone has switched to the vrp aluminum towers and zero issues. They are solid and look really good on the car. I personally like the option towers front and rear, they have a hole between the very inside and middle holes. They just eliminate the very outside hole completely. Very cool in my opinion.
You've seen lots of people using the Al vrp towers? Are those people finding that instead of the towers breaking that other parts are bending or breaking? Something has to give in a crash. I'd rather have a tower break than a chassis bend, shock shaft bend, etc
#3532
Something is definitely going to give. Shock caps, gearboxes, on a hard enough hit mind you. I remember when I was running a B44 (OG car), ran the aluminum tower mounts and went through rear towers weekly. Put the plastic part back on, and they didn't break as often. Someone should make a 4mm rear tower out of good carbon fibre. Mine are still fine, but that rear tower seems pretty weak.
#3534
#3535
just a few build questions as my kit is in transit..
did you tap the screw holes in the parts or just screw in?
is green goop totally necessary to build the shocks?
will the TLR22 alu servo horn work?
any other tips on building? i havent built a kit in over 20 years.lol
any other things i should consider upgrading while building like pistons/springs for a small high bite indoor carpet track?
#3536
Hi Lunchie, I didn't find it necessary to tap any of the screw holes- screwing everything in cut the threads without a problem. The manual points out spots where it is important not to over-tighten. Perhaps the ball cups would be the most best place to pre-tap if you wanted to, but I found that by greasing the turnbuckle threads (another suggestion from the manual) they also cut their own threads easily.
I used green slime because I had some. It doesn't cost much, so I think it is worth doing.
You'll need metric hex drivers for this kit, an obvious change from 20 years ago. And wheels and tires don't come in the kit. I avoided cutting a hole for the antenna tube by bending it into an arch from one side of the car to the other, using both mounting holes.
I found Tony Phalen's build guide helpful for building my B6D. I found this similar guide for the B6D by Joe Navarro.
#3537
#3538
did you tap the screw holes in the parts or just screw in? Not necessary
is green goop totally necessary to build the shocks?Not necessary but helpful
will the TLR22 alu servo horn work? Yes and no...depends on the Servo and shims
any other things i should consider upgrading while building like pistons/springs for a small high bite indoor carpet track?Get the brass front bulkhead and brass Lipo weights
#3540
My track is going from 17.5T+boost allowed to two separate classes, 17.5 stock and mod. I'm thinking about buying another car and running both classes. Would you set them up the same as far as weights, oils, springs etc? Or would you run a light car for stock and a weighted one for mod? I understand lighter is best for stock, but will switching between the two screw up my driving enough to matter? Running on Astro for what it's worth.
Right now I'm thinking I should just build two cars with the same exact setup and different motors.
