Like Tree28Likes
TLR 22-4 THREAD
Old 03-11-2014, 08:32 PM
  #4051
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Skeeter36
How are they wearing out that fast??? I probably have 75 packs through mine and mine still feel very tight. I wonder if they are getting a very small bend in the shaft and it just eats the joint up? These things are supposed to be better than CVD's but I'm no engineer.
I don't know how it did this. The opposite one looks okay but there is some wear, small metallic specs. Maybe 10 degree casters? The bone is straight as can be. I did find a set on Amain. I will be keeping them lubed from here on out.
UN4RACING is offline
Old 03-11-2014, 09:11 PM
  #4052
Beau S's Avatar
Simple answer = you plum wore them out!!
If you literally have 100packs on that car, saying conservatively ~5-6mins/per pack.
That's 500-600mins (~10hrs straight) of track time!!!! I don't get that much track time in a season.
You simply cracked one side of the pressed in pin off the universal from 10hrs of racing.. and if you look at the rest of the parts, they aren't worn like I would figure they would be after that much time & use!!
Universals are better performance-wise in many ways... there are tons of articles about the advantages/disadvantages of Universal vs CV vs CVD Joints.. Distance between & number of pivots, etc.. that's even been addressed in this thread, and is why the 22B has Universals as an option part not! AE swore by the Universals(non re-buildable) until they went CV... Shuey still uses and swears by Universals, and they are not re-buildable either.
I'm sure you could contact MIP and they can tell you the pieces you need to make a set for the 22-4 if you want them.. Ive done that before.
Geez... 100packs of run time on any car without replacing major things, just cleaning and maintenance.. I would be bragging about that car, bcz I don't think I've had a car that didn't require replacing gears, axles, outdrive, driveshafts, dog bone, arms, Pins, pivots, ballcups, etc.. after that amount time!
And you haven't mentioned a Belt Failure, after 100packs... I'm truly impressed by that!
Dam, Son.. you've rode that thing hard.
Beau S is offline
Old 03-11-2014, 10:06 PM
  #4053
UN4RACING's Avatar
Dam, Sonou've rode that thing hard.
I can not agree with you more.
Heck I can do 8 packs on a practice night easy. And I really have drove the heck out of this kit. Seriously I mean business when I practice and race, and I have done that every Tuesday since I bought it. I have hit the track at least 3 times a week ever since I bought it. And a few of the weeks since its release I have hit the track 5 days a week. We did discuss this tonight. The kit is still tight and we gave it a pretty good looking over. Vs. other kits I have driven they would be all slopped out by now. I did break one front belt after 4 days on the kit. Boo Hoo I had the slipper to tight. Since then I would say I am more than happy with the belts with no issue and a proper slipper adj. I am very pleased with this kit to say the least.
It hit the track on the 25th of Jan. So lets say I have conservatively ran 20 packs a week for 15 weeks. Trust me that's a conservative number. So it would be to date 120 packs. I would be willing to bet more like 150 packs.
So yeah I am very happy that it wore out vs. breaking. I have to say that nothing on this kit has been broken due to poor quality. Breakage has been only when you would expect it to break. And it has not broke more times when it should have than the times it did when it should.
I am attending the March mayhem in 2 weeks so this thing is going to get a complete overhaul. And I meant towers cups diffs you name it shock shafts seals lay shaft. I have stock piled the parts since I bought it. If it breaks from there then I will throw the still good old parts on to fix it. In all honesty It really doesn't need it but its the last big race of the season. I want it a new as possible.
All I can say is aside from the front hinge pins if it broke it should have and if it wore out it should have sooner by any manufacturers standards. And I see they have fixed the hinge pin issue.
I do think the rear axle needs some looking at though. The weight of the kit is the demon there. I have killed 2 one was my fault the other was when I let some one test drive it. It looks like if the threads were shorter they would be stronger??
Any hoot its a long post but the short sweet truth is this kit is solid. And that's good news. I have pounded this kit and I feel that our track is a very good testing ground. Its kept me up front and with stood the test of time in hours. IMO. I have absolutely no disappointment in this kit what so ever.
Old 03-12-2014, 06:51 AM
  #4054
Beau S's Avatar
Fastlane is one of my most favorite tracks! I've only been there once, for the JC Indoor in 2012(had to miss 2013), and y'all are very fortunate to such a great indoor place!
I'm planning on being there this year, if the JC race is coming back again!
I still have the pic of the dead deer laying out on the 1/8th track! lol
Beau S is offline
Old 03-12-2014, 07:00 AM
  #4055
UN4RACING's Avatar
I will for sure pass that on to Chuck. I felt bad for that poor deer. I guess he got hit by a car and made it that far. We ended up taking him further back in the woods with the bobcat. That was an odd deal... he sure was a big one.
Old 03-12-2014, 08:06 AM
  #4056
AE
Universal driveshafts create less friction throughout the suspension travel and steering throw compared to CVD's. On bumpy tracks the universals usually allow the suspension to work better throughout the travel. Since the tracks have become more groomed and smooth, the benefits of using uni's aren't fully realized. CVD's bind more (lock-up harder under acceleration) which in some cases produces more mechanical grip which is why almost all 2wds use CVD's/CVA's.
It's pretty amazing that you were able to put over 100 packs through your wheeler, I would say that is a respectable wear rate. I would think that MIP is looking into making a line of replacement driveshaft (uni and CVD) but I can't say for sure.
Dyno Dan is offline
Old 03-12-2014, 08:15 AM
  #4057
UN4RACING's Avatar
Ya know thats a good point. Our track is not a blown out bumpy but some what bumpy. This kit really soaks the track up. I am going to note the cvd universal comparison. If they offer a cva in the future it would be a good option track to track.
Old 03-12-2014, 08:51 AM
  #4058
so far i can only find one fault with my 22-4 and that its way to fast for its operator. i am going to have to turn the throttle down some or keep spending time fixing it . i went 4 packs on my 22 2.0 yesterday without stopping but couldnt get through 10 laps with the 22-4 . which is totally my rust of being out of hobby for about 20 years. i must say i was whipping around the track on the 22 2.o but that was with mid motor and stock 17.5 turn motor . nowhere near the speed of the 22-4 with a 7.5 turn motor in it .
tlr224 is offline
Old 03-12-2014, 08:56 AM
  #4059
drepus's Avatar
You have the right idea. Turn down the full throttle epa untill you are comfortable then turn it back up a little at a time as you get the flow back.
I see too many guys at our local track trying 4wd for the first time with motors that are too fast for them getting frustrated because they cant keep up with the cars. It wont take long to get used to the increased speed if you start with something you can keep up with.
Have fun and put in those laps!
drepus is offline
Old 03-12-2014, 09:10 AM
  #4060
thanks drepus ! i would be doing good for awhile then other cars in practice would distract me and i was going way to fast or the walls are way to strong !!! they say sometimes going slower is faster def true for me ! i say this i can change a arm in no time flat and it isnt weak its if u drive that fast into a wall somethings going to break totally my fault not the cars .
tlr224 is offline
Old 03-12-2014, 09:19 AM
  #4061
gticlay's Avatar
Trader Rating: 14 (100%+)
Maybe I'll put some bicycle chain dry lube on my universals. You can get all kinds of different versions - some thicker, thinner, etc. They all go on wet to soak some of the dry lube into all the places it needs to be they dries off and just leaves non dirt attracting lube. It actually helps repel dirt because it's slippery and sloughs off a little bit over time.
Anybody try that?
http://pedros.com/products/clean-and...e/ice-wax-2-0/
or
http://www.triflowlubricants.com/pro...lubricant.html
gticlay is offline
Old 03-12-2014, 09:22 AM
  #4062
Beau S's Avatar
+1
Beau S is offline
Old 03-12-2014, 10:56 AM
  #4063
splashn95's Avatar
Anyone know if a Mamba Max Pro 1/10 will fit in the limited space that the 22-4 gives ya?
splashn95 is offline
Old 03-12-2014, 12:38 PM
  #4064
No.... I'll spare the "why"
If you are that desperate for arms, use http://www.amain.com/product_info.ph...Wishbone-Set-2
You'll have to drill the inner hinge pin holes to 3.5mm(very easy to do, the drill bit is cheap), the Shuey Cats are 3mm pin holes & the arms are time tested.
I am not sure if the outer hole would/not need to be drilled out, too..
These arms are just as beefy as the stock 22-4.. and matched perfect in geometry to the xx4 arm, which is pretty identical to the 22-4.. Kind of a fun fact that Shuey has been running XX4 geometry for many years
I mod'd my xx4 to run these arms using the 22b front hinge pins.. it was pretty solid! Hence, using the medium flex. Here you can see what they look like
http://www.petitrc.com/setup/losi/se...chumacherArms/
I might still have a set of these arms in a box.. I'll look when I get home
I'll bet you can probably find 22-4 arms somewhere & not have to worry about all the above.... but its there for the no other option racers.
I no longer have a set of the shuey arms to spec and take pics off, but other than drilling the inside hinge pin hole to 3.5mm, you would only have to drill the outside hinge pin hole to fit the 22-4 King pin screw. I forgot to mic one last night, so I don't know what size that is. Then mount them!!
I know some of you are headed to Cactus, so whoop some booty boys!
Thanks for the help. I wasn't able to find any xx4 arms yesterday but that's okay since it sounds like they won't work. I'm headed up to amain after class today to get a couple sets of shuey arms. Track is so hooked up, i dropped 1.3s on my fastest 2wd lap yesterday. I'm ready to get my wheeler running. I'm also going to get some skid plates(noticed my lrc block is getting worn away) and a sway bar set. I hope this fix will work, amain is a 4 hour drive hehe.
TorcRacing is offline
Old 03-12-2014, 01:48 PM
  #4065
Beau S's Avatar
The xx4 arms do not have enough meat around the pins... and would break very easy in comparsion.. just say NO!
The Shuey arms... they come in standard and Med Flex.. I would go with Med-Flex..
I would think Amain probably stocks Drill Bits & can probably mic the 22-4 Kingpin for you, too.
I'll double check what # the drill bit I used, & the shoulder size of the 22-4Kingpin, when I get home.
edited 03/13/14
A 9/64" or #28 Drill bit for the inner & outer hinge pin holes on the shuey arms, then follow http://www.rctech.net/forum/13093860-post4088.html
Beau S is offline
