TLR 22-4 THREAD
#4021
#4024
#4025
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Loose diffs allow the tires to work more independent. By having the front tight the kit will have more push going in and more pull coming out.
It sounds like its time for a diff rebuild how old are they?
Or maybe you just have the front to loose.?
#4026
Trader Rating: 27 (100%+)
I broke one arm each side but never broke a pin so I'm thinking the domino effect may not be the case all the time.
Since bracing the front arms I've broken none and our track now has bigger jumps and I'm still gettin out of shape and crashing, only harder lately.
Been running Gold Barcodes V1 with closed cell foams front and rear and they hold up pretty well on our hi bite clay
![Frown](https://www.rctech.net/forum/classic_images/smilies/frown.gif)
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
#4027
I was assuming it was sliding or breaking loose. Over steer is what you are saying I guess.? But if the rear diff is looser than the front it will lock the rear end in. By having the front tighter it will take steering away entering the turn.
#4028
I would tighten it if its over steering. "Allowing" a diff to rotate generates grip. Not allowing it to rotate decreases grip.
Utilizing this effect is the hard part. Our track I am running about 3/4 of a turn rotation front and rear. But if the grip is real good I will run the front slightly tighter around half a turn out. If I run them to tight on our track it skates threw the turns.
Nice thing about ball diffs is you can adjust it on the fly even in warm ups. Finding the perfect setting sucks...LOL
I am going to send you a PM
#4029
Can someone help me with the rear belt tension options. I understand that there are different inserts that can be used. But I'm not sure I follow the "A Back" vs "A Forward". Is the arrow what makes the forward vs back distinction? If so I don't think I have the inserts with alternating arrows.
#4030
exactly!
How does a tight front diff(understeer in & out of the turn) make the rear-end over-rotate?!?!?
A more responsive(oversteer) front-end is more likely to aide in rear over-rotating..
He said it "suddenly" changed, which diffs that need a rebuild typical do not rotate smoothly, thereby reducing rotation and can cause it to come around on you in/out of turns, and makes the car feel less planted thru the turns... If that's what he is meaning by "rear end over rotation"..
Casper, Hacker, Frank?!? any input on front & rear diff tightness and its effects on 4wd In & Thru out the turns, and traction bias?
#4031
#4032
When a "kit" not diff rotates a turn the diff is the first thing to effect the suspension. Then its onto roll centers links etc. and shock oils and so on.
My order on a box stock set up. Diff, Slipper, oils, the links, wheel base, then roll center. Sad but true no matter the process its a never ending battle one track to the next.
To his point is yes it could be the dirt water no water ambient temps and so on. But if there are no changes made to the kit and its goofing up out of the blue, I would for sure start with the diffs and inspect bearings and belt tension.. It sounds like he has tried everything else?
Not sure this helps but with out being able to see drive or consult while at the track its pretty difficult to help on the interweb.
#4033
+1 UN4RACING, I think where a lot of the diff tightness confusion comes in is some have observed that at times tightening the front diff helps the front rotate, however it is usually on throttle with a lot of front roll stiffness (stiff springs, stiff bar, high roll center).
This is very evident in touring cars using a locked front diff with stiff front springs. The car will not hardly turn at all unless you are on throttle because the tires are fighting each other until the inside front tire is unloaded.
So if you are using close to a conventional setup, as UN4RACING stated, you want the front slightly stiffer that the rear but not over tight so the tires are not fighting each other to rotate.
#4034
#4035
