TLR 22-4 THREAD
#2551
Maybe I missed something in the instructions or in this thread, but when spacing the left-side pack forward, what goes behind that pack, to keep it securely forward/in place?
Also, it seems I might have to put a little foam or something under the battery hold downs, as my packs fit a little loose under then, and don't feel locked down. Anyone else run into this?
Lastly, did anyone else have to dremel or file the right side hold down, to clearance the bullet connector for the inside battery terminal?
Thanks!
Thanks!
#2552
Thanks!
Thanks!
#2553
It would've been sweet to have the same type of battery "stop" in the back of the left side pack, as in the front. Remove the rear stop for back, and put it in, for front.
#2554
#2557
If you can't get replacements in time you can always slot the top of the stripped screw with a cut off wheel in a dremel. Then use a slot screw driver to install it.
#2563
Hey does anyone want to trade wheels with me, I will have the yellow ones and I run white. Yellow is up for trade for white.
#2564
Thanks!
Thanks!
