Serpent 811E Buggy Thread
#3166
We are currently working on the English site
I will also have an start running on Monday (I hope) on Rctech. We are in the process of installing OSCommerce in the back ground.
So yours and your friends wishes will come true soon
in the mean time you can always send me an email for parts until the site is up and running...
. Cant wait !Hope you will be accepting paypal payments
.Dont forger drop msg about your shop on uk forums.
w w w.maxbashing. c o m
w w w.oople. c o m
w w w .msuk-forum. co . uk
#3167
v2.0 upgrade and all the nifty stuff in stock
building my GT right now
#3169
Regards
#3170
I keep restocking for Serpent and Novarossi. Sweep sales are a little on the low side at the moment as its winter and everyone here hybernating.
I hope the transaction and service was good.
Serdar
#3173
#3174
So just got my Serpent 811-BE Built and ready but I was looking at the center diff and it has been leaking not out of the outdrives but where the spur meets the case? It has only had the throttle on once to make sure the electronics were working, but its never been ran on a track. So any ideas? Thanks can't wait for outdoor season to start to run this thing!
#3175
#3176
Zero Force Serpent 811e Bearing kit set (20pcs) (ZF-B11015)
Zero Force Serpent 811 Bearing kit set (20pcs) (ZF-B11001)
Zero Force Serpent 811 TE/2.0 Bearing kit set (18pcs) (ZF-B11011)
www.rcgoods.com
www.rcgoods.com
#3177
Thanks Blake
#3178
Originally Posted by Maxxingout
Did you make sure you put the spur on flat and tight. Also it takes a bit for the paper gasket to seal. Also if you over fill the diff, that'll cause leaking also, just some ideas.
The spur is on tight and straight but i may of over filled it. So should i clean the outside up then not take it apart and wait to see if it leaks?
Thanks Blake
Thanks Blake
5Likes
