Serpent 811E Buggy Thread >
Like Tree5Likes
Old 06-25-2012 | 06:50 AM
  #2416
My snake I finished assembling yesterday. Just have to mount the esc and I'm awaiting batteries! Can't wait to get this car on the track.
f41stryker is offline
Old 06-25-2012 | 07:26 AM
  #2417
PurevilSerpent's Avatar
Hey Guys, after much reading, I pulled the trigger on a Serpent 811 BE. Shipped from A-main today, so Im a happy guy. Thanks to this forum being super active, there is a TON of information here and really made the decision process easy. Looking forward to the build and contributing here!
PurevilSerpent is offline
Old 06-25-2012 | 11:20 AM
  #2418
weavty1's Avatar
Thumbs up
Welcome aboard!!!!
weavty1 is offline
Old 06-25-2012 | 03:21 PM
  #2419
Does anyone have a picture of something other than a Tekin wired up in this buggy? Hobbywing is what I'm after.
peter_robinson is offline
Old 06-25-2012 | 03:51 PM
  #2420
RCmayor's Avatar
Its a tight fit, but got er done. The sensor cable comes out on the side where the motor wires are. Had to drill a hole in the mount. Ended up using the stock sensor wire. Was going to get a shorter wire but it works fine as is.
The wires are stock on the speedo, I didn't have to re solder anything the way it is mounted. The switch and receiver wires are just taped over so they wouldn't get chaffed by the body. I did hack up the receiver box cause the wires wouldn't fit, and it really doesn't need to be enclosed fully. Since the lid isn't there the antenna tube exits through a hole in the back of the body. I used the original 811 gas car antenna mount.
RCmayor is offline
Old 06-25-2012 | 09:04 PM
  #2421
Ok I've never ran this dual pack setup and was wondering this: if a battery doesn't have the tube style connector, would it be possible to solder a bullet connector on a positive and negative lead of each battery and hook them together like that?
Old 06-25-2012 | 09:10 PM
  #2422
RCmayor's Avatar
Originally Posted by Vortexted
How long have you been running the red?
I went through a red and green in the truggy, and a green in the buggy all in 2 weeks My green in the buggy lasted about 2 months.
On the plus side RadioPost was quick to replace with new ones, but I sold them.
I shelled out the big $$ for the KO PROPO's now and I can feel they are much smoother. If I can get at least a year out of them it will be worth every dollar.
Pulled a 4th tonight on a 13 car field of experienced drivers. Sometimes I just love how hassle free the Serpent electric is.
But other times I just love the smell and sound of nitro.
I was going to put my BE on the shelf for a while and buy a 811 TE nitro buggy but I don't know, keeping up with nitro truggy and buggy would be some serious work.
Since like Februrary. I have about 3 hours on it. Mix of tracks. Probably should have put the red on in the buggy. It is plenty fast.
I've never ran one on throttle in the gas buggy though.
RCmayor is offline
Old 06-25-2012 | 09:12 PM
  #2423
RCmayor's Avatar
Yep, shouldn't be a problem. The bullet connectors in the packs are a little cleaner looking but its all the same really as long as you cut the wire to the right length. Depending on where the wires come out of the pack you might need to cut the battery tray a little though but that shouldn't cause any problems. The battery trays are pretty solid.
RCmayor is offline
Old 06-25-2012 | 09:28 PM
  #2424
Great, thanks. I have a couple gens ace 40c packs coming with the removable leads but if I ran across a good deal with non-removable I just want to make sure I can use them.
Old 06-25-2012 | 10:09 PM
  #2425
Welcome to the snake pit
I went bashing with my e buggy at the park today. Amazing how fast this thing is when you can just open it up and let it run.
Vortexted is offline
Old 06-25-2012 | 10:14 PM
  #2426
3 hours isn't long. I used to run the plastic servo horn and stripped 3 of them. That probably saved the servo as long as it did. Wasn't long after switching to alum that servo went out. Hopefully you will have better results then myself and the other racer here using RP.
Old 06-26-2012 | 07:54 AM
  #2427
I went ahead and orgered an aluminum horn for mine. I assume you can use one of the countersunk washers to affix the horn to the steering arm correct?
Old 06-26-2012 | 12:23 PM
  #2428
Thanks, I did something similar to this. I'll post pics when it's totally done.
Old 06-26-2012 | 02:44 PM
  #2429
protc3's Avatar
I made a set of countersunk washers for my 811 today. I also made some delrin pistons i want to try out. This car is alot of fun and i didnt even run it yet.
protc3 is offline
Old 06-26-2012 | 04:53 PM
  #2430
weavty1's Avatar
Thumbs up
Care to make me a pair?? Those look great man! Must be nice to have access to a machine shop!
weavty1 is offline
