Serpent 811E Buggy Thread
#1667
Hey guys, just ran into a small problem. These shocks are much bigger then what I'm used to and I don't have the right tool. I'm assuming I need an open end box wrench to hold the shock body in place while screwing the other components in? What size?
My Losi SCTE kit came with a real nice shock bottom wrench for holding the shock in place while wrenching and not scratching the schlock.
http://www.amainhobbies.com/product_...Tool-Set-Ten-T
Anyone know of one for these 811 stocks?
#1668
I don't think many have used that plate, I would say if you had it probably a 4 down insert which should be 3 degrees. Not sure on that, maybe 3.5. It also depends on which rear bracket you have, the stock will be less anti squat and the Low Roll will be more AS.
#1671
hi, im a new cobra pilot looking for more off power steering from the front of the car.
it finishes the corner great .
but doesn't turn in as hard as i would like.
im racing on wet to drying high bite indoor clay/soil mix.
i have tried all the tires the leading racers use .
with the same results.
if i have to get steering from the rear of the car .
i will .(but would prefer not to ).
thanks for any help/advice.
#1672
im running porkchops setup from page 89.
8 hole conical pistons.
i went to 40wt front , 30wt rear.
blue and yellow springs .
have not tried the 2.8 bar yet .
i took a little bit of droop out of the front
to help change rotation in the twistys
also , has anyone tried running this car light?
i have found some 3800mah / 50c lipo's
that weigh 208 grams.
compared to my 5600mah packs.
that weigh 313 grams
#1674
Thanks Porkchop, good idea.
My Losi SCTE kit came with a real nice shock bottom wrench for holding the shock in place while wrenching and not scratching the schock.
Anyone know of one for these 811 schocks?
a hole on the castor block
longer rear hubs
up on the rear link on the tower
2 up front kick up 2 down in the back
hard servo saver spring
#1675
#1676
I shoe goo-ed mine to the back of the servo.
#1678
I started off yesterday morning real bad. Turns out one my bottom shock pieces was a factory defect is why it would not go on. I had to force it with vice grips and thin crescent wrench only for it to crack in half. Like it had bad threads inside. The other 3 went on hand tight just fine. Not a good start to my day. Hopefully it will hold up for practice tomorrow, had to express mail more to me.
The good news is after taking a day off work the car is almost finished and I'll be on the track later today
Man this car is tough to set the gear mesh, but I think I got it figured out.
Chops how many pages back did you post a setup?
I set mine up for Frank L Nitro Challenge setup, hopefully it works for me. I'll post some pics in a day or two.
Can't wait to get this bad boy on the track
#1679
#1680
Guy i wanted to join the snake pit so i just ordered my 811E and i kinda new in 1/8 ep buggy never try it before, i will be running at a local track is a tight track with low traction the surface are mostly soft dirt and condition are dry and dusty. maybe some advice on what i should start off with exp: shock oil F&R also the diff oil for front centre and rear, kinda new in buggy and not much knowledge hopefully you guy could help me out, thanks.
5Likes
