Serpent 811E Buggy Thread >
Like Tree5Likes
Old 02-16-2012 | 10:29 AM
  #1516
Maxthepersonz's Avatar
If someone has a video of that CRCRC win I would like to see it! Pretty sure the B main is on youtube but not the A.
Maxthepersonz is offline
Old 02-17-2012 | 01:18 AM
  #1517
porkchop's Avatar
Originally Posted by No Idea!!
mine has leaked aswell,going to use Mugen gaskets
the serpent gasgets fine once it wet. and after about the second refill they stop. due to the oring soked up enought oil
the big issue is if your overfill the diff they will leak and your car push out the door.
pull all the gears out put 2mm oil in then the big gear spin outdrive. then add crosspins and gears then fill to just the top of the crosspins add the next big gear. then line up the top and the diff case screw toughter now your diff got room to expaned and not leak.
car looks great
i just looked it up it was wrl round 4 and there no vid up yet.
porkchop is offline
Old 02-17-2012 | 06:42 AM
  #1518
car looks great
Is someone going to post one?
Old 02-17-2012 | 07:45 AM
  #1519
bronc4now's Avatar
Default lipo straps
Few ?'s about the battery straps
1st how fast can you change out 2 lipos in a race and is it faster then velcro straps ?
2nd has anyone had a problem getting into a race not using velcro straps ( ROAR legal )
3rd has anyone trying to drop weight thought about taking the doors off and replace with a carbon fiber strap across lipo ? Would it help ?
bronc4now is offline
Old 02-17-2012 | 10:55 AM
  #1520
The doors are very light. Probably equal to carbon fiber it would be a "pointless" thing to do just for looks. Not sure about issues with ROAR I think it has been fine. (porkchop would know)... It would take the same amount of time I think. Depends on if your better at taking velcro off or body clips. Personally the trays seem far easier..
Old 02-17-2012 | 11:44 AM
  #1521
rcq
Hi
Need some advice. What should I change of front of buggy for better stearing on throttle?
rcq is offline
Old 02-17-2012 | 12:13 PM
  #1522
netmaster's Avatar
Originally Posted by rcq
Hi
12 degree caster blocks
thicker front diff fluid
less front droop
more anti-squat
thicker rear sway bar
longer wheelbase
netmaster is offline
Old 02-17-2012 | 05:13 PM
  #1523
tony montana's Avatar
Im mean really can we get a little bit bigger radio box or even a taller lid would work.
tony montana is offline
Old 02-18-2012 | 12:46 PM
  #1524
More like an 1/10.... the way it should be...
puttekula is offline
Old 02-18-2012 | 12:51 PM
  #1525
Davidka's Avatar
The irony is thicker than 10k diff oil.
Davidka is offline
Old 02-18-2012 | 07:58 PM
  #1526
bronc4now's Avatar
thats nice !
Old 02-19-2012 | 02:58 AM
  #1527
man that thing as a low cg
aceinthesky is offline
Old 02-19-2012 | 05:18 PM
  #1528
Will these fit? Anyone use them, worth the money?
http://www.amainhobbies.com/product_...es-74V-6500mAh
infanterene is offline
Old 02-19-2012 | 06:19 PM
  #1529
KIK's Avatar
KIK
Yes they will fit, but do you really want to spend $270+shipping on 2 packs? I'm not saying the Orion packs aren't good, but at the same time I'm not gonna spend that much money on 2 packs.
I run these and it cost me $174 with expedited shipping for 4 packs.
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
KIK is offline
Old 02-19-2012 | 06:28 PM
  #1530
My first choice was the hobby king nano tech 6600's but they are out of stock. I got the Orion packs for about 40% cheaper than that if not I would have waited for the hobby king ones.
Can you run 15min on those 5600?
