Like Tree5Likes
SC10 4x4 Thread
Old 11-21-2011 | 08:26 AM
  #11251
bcrazy's Avatar
Default Ready for battle
bcrazy is offline
Old 11-21-2011 | 08:39 AM
  #11252
MantisWorx's Avatar
nicely done my friend!
MantisWorx is offline
Old 11-21-2011 | 08:47 AM
  #11253
brent701's Avatar
Originally Posted by bcrazy
that looks bad ass. What would a paint job like that cost someone?
brent701 is offline
Old 11-21-2011 | 08:48 AM
  #11254
So marcus, in ur opinion woulld i be hurting anything leaving the brace???? Btw what day u sending out ackerman bars??? My brother in florida orderd mine
rickybobbyxxx is offline
Old 11-21-2011 | 08:51 AM
  #11255
JEFFs SC10's Avatar
That body is sick, I would love one in lime green.
JEFFs SC10 is offline
Old 11-21-2011 | 08:58 AM
  #11256
JEFFs SC10's Avatar
I still dont understand what the pin mod does LoL . I am looking to get every advantge I can get LoL.
Old 11-21-2011 | 09:07 AM
  #11257
Wild Cherry's Avatar
Tech Legend
On slippery surfaces or outdoors the pin works well, indoor clay no pin performs better ...
Wild Cherry is offline
Old 11-21-2011 | 09:36 AM
  #11258
Is this the consensus? I have only run on my pinned mod once on a good sized indoor clay track. It ran pretty good. I guess I'll try a few more times pinned and then decouple and see how it goes that way.
jamr1130 is offline
Old 11-21-2011 | 09:41 AM
  #11259
brent701's Avatar
I have also read when not pinned run the 19T front pulley. When pinned run both 20T.
I had it pinned on a indoor small clay track. worked ok. Unpinned and front 19T pulley was much faster and handled better.
brent701 is offline
Old 11-21-2011 | 09:44 AM
  #11260
Man the body looks sick and for being ready for battle your not going to far w/o wheels and tires lol good luck with that you will be the fastest setting still lol just playing
special_k is offline
Old 11-21-2011 | 09:47 AM
  #11261
Thanks for the tip. More options for me to try.
jamr1130 is offline
Old 11-21-2011 | 10:09 AM
  #11262
Mizchief's Avatar
Take a look at your slipper setup, notice how the outer most plate has a square hole and is keyed to the shaft while the inner plate has a round hole, but then a square backing to lock it to the rear belt pulley.
What the stock setup does is allow the belt to slip independently from the rear, so while slipping the rear will always turn as long as the plates are moving since it's keyed to the shaft, but then the front pulley plate can slip to the point where no power is going to the front wheels especially during the first moments of acceleration when there is weight on the wheels. which is often the opposite of what you want to happen.
The pin mod locks that inner plate to the shaft just like the outer plate so that any time the shaft turns both front and rear will turn instead of letting the rear slip faster.
This is why people recommend the 19t up front with no pin mod, this will make the front wheels turn faster with the limited amount of power given by the slipper, where the pin mod accomplishes this by locking down front and rear.
Speaking of which, does anyone know what the front/rear bias actually is when using 20t for both pulleys and the pin mod? Does it make it true 50/50 (or 100/100 forget what the notation is) ?
Mizchief is offline
Old 11-21-2011 | 10:13 AM
  #11263
Mizchief's Avatar
Very nice, did you hand airbrush the flames and watermark or did you use a stencil? I've got a buddy who is into tattooing and is handy with the airbrush, I was thinking of letting him do a body for me then offering custom paint jobs as a side business if it turns out well. Seeing as how AE charges like $60 for their custom bodies I think we could do pretty well selling pre-painted custom bodies.
Mizchief is offline
Old 11-21-2011 | 10:16 AM
  #11264
Mizchief's Avatar
Until the exotech came out I was thinking about going down to my local machine shop and getting some steel plates cutout that I could then screw to the bottom of the center chassis with different weights via different thicknesses. I don't think it would reduce the flex the the exotech would, but should help a little if done right, then you could tune the weight to the track.
Mizchief is offline
Old 11-21-2011 | 10:34 AM
  #11265
JEFFs SC10's Avatar
I used the 19 tooth outdoors on loamy and it felt like it overdrove the front wheels too much. I can see how it might work on a very tight technical course.
Why are idler gears breaking because of the pinning? Is there a metal replacement available?
