Like Tree5Likes
SC10 4x4 Thread
Old 11-20-2011 | 07:23 PM
  #11221
JEFFs SC10's Avatar
I put some lead weights in the slots on the side and it made a difference so yea I'm sure it did make the truck feel a lot more planted.
JEFFs SC10 is offline
Old 11-20-2011 | 07:30 PM
  #11222
symmetricon's Avatar
The exotech chassis felt much different than the stock center piece, even with 4oz of weight added to it. The rear end is more planted, no washing out in the sweeper. I also did not have any tracton rolling issues anymore. I can now fly into the turns like the losi's can. I drove another racers losi, he said it was dialed, and I found that my sc10 felt very similar to his losi, except i had more steering, and my sc10 rear end was more locked in than his. I almost couldnt believe it. The chassis is SWEET!
symmetricon is offline
Old 11-20-2011 | 07:32 PM
  #11223
JEFFs SC10's Avatar
that's a great report. have you guys done the yellow spring/yellow sway up front and blue sway blue spring out back?
on my stock chassis it made a difference. Now i'm pumped to get this chassis.
Old 11-20-2011 | 07:33 PM
  #11224
Chad Smith's Avatar
Crap! All these good comments on the exotek chassis I guess I have to buy it! lol
Chad Smith is offline
Old 11-20-2011 | 07:41 PM
  #11225
i am running yellow spring front and rear, and yellow sway in front and white sway in the rear. without the chassis, on a high traction track i had to run the 2mm swaybar in the rear to keep from traction rolling, that change would sacrifice rear grip. Not any longer
Old 11-20-2011 | 07:56 PM
  #11226
CoyoteSlash's Avatar
Originally Posted by Resqnu
What. Hauler/bag are you guys using for the sc10 4x4? I am looking to put 1 or 2 sct in a hauler, charger, batteries and parts. Any suggestions appreciated.
SCT Backpack
Originally Posted by jmoneym
Just installed the CoyoteSlash brace great price.
[IMG]image[/IMG]
Thanks alot Jmoney! Hope it does you right. Truck looks good and clean. Change that!
CoyoteSlash is offline
Old 11-20-2011 | 08:15 PM
  #11227
marksp's Avatar
anyone have install instructions, tips/tricks, etc. for the fastlapproducts chassis brace? Tried e-mailing and scrubbing the web site, but no response. Just like to be certain before firing up the drill!
marksp is offline
Old 11-20-2011 | 08:29 PM
  #11228
beyondthepack's Avatar
Basically ur using the front hole from the body mount. after that is attached, mark the rear hole where the back end rod sits on the transmission. Drill away
beyondthepack is offline
Old 11-20-2011 | 08:30 PM
  #11229
Default front hole
Old 11-20-2011 | 08:35 PM
  #11230
U guys think theres any downside of using chassis brace with exoteck chassis?? I know it may not be needed but im about to put a pretty crazy moter in it and i dont want no belt issues
rickybobbyxxx is offline
Old 11-20-2011 | 08:43 PM
  #11231
I don't think it can't hurt any. 1/8 buggy's have aluminum chassis, and use a front, and rear brace
Old 11-20-2011 | 09:11 PM
  #11232
I won't hurt at all. I truly don't believe 100% of the flex is out of the chassis. But depending on the track, flex is 'good'. That's why I don't have any plans on purchasing a Exotech. Unbolting a Chassis brace for flex over removing that god awful chassis is so much better. It's a tuning option over a replaced part. (my opinion)
Bottom line is the chassis brace does it's job. The exo (if you don't care about wanting flex depending on the track) does two jobs. Weight and a bonus: eliminates most flex.
Old 11-20-2011 | 09:24 PM
  #11233
BLbound's Avatar
Ok Mantis...I need to replace my slipper pads so I went with your garodisk slipper pads...I'm excited to use them and hopefully I get them before this coming Friday .
BLbound is offline
Old 11-20-2011 | 09:36 PM
  #11234
CraigMBA's Avatar
Seriously? But but but....
Originally Posted by sedemente
But my opinion is this is business 101 , who can make the best product,for the best price , and give the best service.
Looks like Billy at Fastlaps has the same product, for a higher price, and no service! Way to go Billy.
Did we ever figure out of the Novak will run the Tekin 4 pole or not? Yeah, yeah, yeah, Novak sucks and all their product blows up as soon as it's exposed to sunlight.
CraigMBA is offline
Old 11-20-2011 | 09:43 PM
  #11235
A novak esc will run the 4 pole motor, but not as efficiently as it would with a dual mode esc like the rx8 or mmp. The Novak esc's base the timing completely off the sensors which are reading at a minimum have 15 degrees of timing. Most guys are running less than 5 degrees in sensorless/dual mode as any more timing does nothing but add heat.
On the flip side I know of several guys that run the tekin pro4 motors attached to an orange esc and while their motor temps are 10-20 degrees above the norm, they seem to run ok for the most part.
Krio is offline
