Like Tree5Likes
SC10 4x4 Thread
Old 12-18-2011 | 10:27 PM
  #12751
Wild Cherry's Avatar
Tech Legend
Default Whata go Fasta ?
Parts you need for saddle pack installation
B44.1
Straps #9786
Tray #9775
Posts #9745
Screws # 6292
countersunk washers (blue) #89229
Started on the set-up , its Codys !!!
Finish the ft end today ......
details
no over drive
10K diff
white sway bar
emulsion shock
yellow spring
32.5w oil
1.2 piston
no internal limiters
no external limiters
+2 turns on shock eyelet
2m rebound
shock position
inside on tower
outside on arm
ball stud outside on tower , 1m shim understud
Wild Cherry is offline
Old 12-18-2011 | 11:37 PM
  #12752
IRM616's Avatar
Is the size of a pro 4 4000kv the same as a 540? Looking for a heat sink. Thanks
IRM616 is offline
Old 12-19-2011 | 12:07 AM
  #12753
IRM616's Avatar
Looking for a heat sink that will fit my sc10 4x4. Any idea of a brand? I know the space is limited bc it sits under trans. Thanks
IRM616 is offline
Old 12-19-2011 | 12:28 AM
  #12754
BorackBasher's Avatar
B44.1
Straps #9786
Tray #9775
Posts #9745
Screws # 6292
details
no over drive
10K diff
emulsion shock
yellow spring
32.5w oil
1.2 piston
2m rebound
shock position
inside on tower
outside on arm
thank you thank you!!! let me know what your set up is for the rear too!
BorackBasher is offline
Old 12-19-2011 | 01:20 AM
  #12755
IRM616's Avatar
Exotek chassis ordered! Question the Garodisc is for the clutch basket? And I can use the normal for the single side? How do you know when your pads are no good? Thanks!
IRM616 is offline
Old 12-19-2011 | 02:44 AM
  #12756
Mac The Knife's Avatar
R/C Tech Elite Member
Originally Posted by macnkitty2002
Thanks for the advice. Could you provide a link to the slipper upgrade you're referring to?
Can't wait to hit the track with this baby. I'm already the king of 1/8 nitro buggy and 2wd SC at my track, now time to take the 4wd SC crown
That would be http://gearrings.weebly.com/rc-racing-stuff.html
Mac The Knife is offline
Old 12-19-2011 | 02:48 AM
  #12757
No, you can run the Garodiscs with or without the clutch basket, and you can run the clutch basket with garodiscs, or standard pads, or the HT pads. Mixing it up allows you to play with how the power gets transferred to the front and rear. Kinda like changing diff fluid in a center diff.
Old 12-19-2011 | 06:15 AM
  #12758
sewerdog's Avatar
can you explain a little on the mixing up of diffrent pads and there effect
sewerdog is offline
Old 12-19-2011 | 06:19 AM
  #12759
TraxxasPeter's Avatar
This truck is the best truck I have owned. I got first in the A with a 540 8.5. First race ever with this truck
TraxxasPeter is offline
Old 12-19-2011 | 06:28 AM
  #12760
Its about grip level, the standard pads are at the low end, hd in the middle and garos at the to fire grip level. The basket allows you to add an extra pad to power the rear of the truck.
On the tuning side of it, most people out a garo or at least a hd pad on the inside to power the front. I put my best pad in the back since the front is only powered by 1 face of the slipper pad. Inside of the basket is where to get creative, 2 garos or 2 sd or 1 of each. 2 sd pads is like running your slipper loose on a 2wd, 2 garos grip more so its like you tightened the slipper down. You have top play around here top find what works for you, I trend to like a lose slipper stop I have a hd pad on the inside and 2sd pads in the basket.
Kbmoss is offline
Old 12-19-2011 | 06:58 AM
  #12761
sewerdog's Avatar
thanks for the info
sewerdog is offline
Old 12-19-2011 | 09:07 AM
  #12762
macnkitty2002's Avatar
Originally Posted by CoyoteSlash
When the RTR is released and all these people come flooding in refusing to read the last 800 pages... I'm going to have a fit.
Good luck getting anyone to do THAT! How is a noob asking a question any different than one of the regulars asking one? Either way, an individual is looking for an answer to a question. We should all do our best to help each other regardless of how familiar one is with the truck.
Thanks for the info Mac The Knife.
macnkitty2002 is offline
Old 12-19-2011 | 09:43 AM
  #12763
Mizchief's Avatar
will the new center diff still need to have the gear cover expanded to fit like with the clutch basket or will the stock cover work?
Mizchief is offline
Old 12-19-2011 | 10:04 AM
  #12764
IRM616's Avatar
Is sd the stock pad?
IRM616 is offline
Old 12-19-2011 | 10:15 AM
  #12765
PastaBoyNY's Avatar
Default Congrats Peter!
Great going Peter! Sooner or later I will make it down to race. Right now it's just practice... I need to knock the rust off!
Sal
PastaBoyNY is offline
