SC10 4x4 Thread
#9181
piston polishing
Hey Marcus you still reccomend polishing your 2 stages. The fit was not super tight against shock body or is it for better flow or something
#9182
For your viewing pleasure: http://www.youtube.com/watch?v=tFI5Sv9Y2c0
im going on a loose large track whit alot off big jumps and alot off lower troutel punch running ( i hope u get what i mean) ballitisk 4,5T and planing to run the 62T spur gear 32P im getting 11,12,13 T pinion for a start. and what temps are u getting ??
#9183
hey u guys running this motor what pinion size are u running??
#9188
re: pinion
the novak pinion is tapered on the end so I slide the pinion on until the end of motor shaft is even with the botom of the pinion taper and it is perfect
#9192
Didnt care for the overdrive/pinned had even less turn exit steering.
OK guys more testing today and i am glad to say that i knocked off another 2 tenths off of quick time and i managed to do it a handful of times. so i started with a 24.9 a few weeks ago and today i blasted a 23.8! changes since last time out were RPM arms, chassis brace and the new Tekin 4000kv motor ( which is INCREDIBLE). am headed out with the fam for the evening but will chime in tonight with the final setup! truck is amazing!
#9195
Edit: I'm a hard running Driver. So that "style" is definitely shielding myself from the less responsive Sensorless motors. I understand.
I'm starting my FT shock build. I ordered SO MANY PARTS. 200.00 worth. God I love my employee discounts...
Old shocks are mounted to my Slash. (what a beauty it makes it.)
6 Idler gears (thought they came individuals. oops)
Shock mounting hardware
FT front and Rear Shock kits
Hazard wheels.
Caliber 2.0 tires
new belt
Yahoo! Yeah... I know that I will never become a Photographer. Xbox controller, and my fat belly. I'm such a champ.
