Like Tree5Likes
SC10 4x4 Thread
Old 05-16-2013 | 03:21 PM
  #34051
Yellow is 2.2 mm blue is 2 mm
9turn is offline
Old 05-16-2013 | 03:40 PM
  #34052
ok thanks i guess i have it the right way then and there wrong lo. all i know it works for me. i like the stiffer sway in the rear for some reason it keeps it planted for me and i can drive it harder that way without it kicking out.
imrob is offline
Old 05-16-2013 | 06:03 PM
  #34053
rjohn929's Avatar
Originally Posted by Jstall7543
Relative? Absolutley. And probably the best bang for your buck in a competitive truck. I agree the truck does have a problem in its FT or team versions, Example: if your already wide open throttle and you hit a big tripple it likes to go nose to the sky. But on smaller indoor track I just blip the throttle and it flies good, but if I hold it wide open its nose up and unrecoverable with brakes. These are my observations. Not looking for any trouble or arguments or angry debates.
That store owner throwing all the barts in the bargain bin is most likely because the truck just doesn't break! I put one of mine thru hell and back on indoor and never broke a thing bone stock for 2 years. then i fully modified a Ft version and broke one titanium ball stud due to 6mm of washers I put under it. Hope this helps. Buy one!
Or when it does break no one wants to go through the trouble of fixing it!
Don't get me wrong, I really like it, handles great and is relatively durable but now that all my diff fluid has leaked out of the rear diff I'll probably park it for a while. It's a pta to take the entire rear end apart and rebuild the diff. I do enjoy tuning and fixing but I would rather have more wheel time then wrench time. It's a shame to because I had it dialed pretty well for our track and it screams down the main straight on two wheels with the pro4 4600 and 14t pinion.
rjohn929 is offline
Old 05-16-2013 | 08:26 PM
  #34054
ovalosi's Avatar
hi guys new owner of an sc10 4x4
currently working on the lowered servo mod and was wondering what yall are doin with the linkage afterwards? taller servo arm or what?
ovalosi is offline
Old 05-16-2013 | 09:20 PM
  #34055
That's because the rooms not unloading on you anymore If you go to front springs in the rear you get the same thing
9turn is offline
Old 05-16-2013 | 09:22 PM
  #34056
Wild Cherry's Avatar
Tech Legend
Won't need to change the servo arm for a longer one , stock fits almost perfect steering rack performs great.
Wild Cherry is offline
Old 05-17-2013 | 10:18 AM
  #34057
Tech Legend
Default Rc 10 4x4 light set-up
Lowered Servo Mod
Can notice this change , truck will be less tippy , less roll...
step 1
*Before removing servo
mark the servo's location on the bottom chassis.
*grind the X brace on botton chassis flush & grind the ridge on the back of chassis as well.
*Mount the blue servo mounts on servo and mark the location to drill holes in chassis.
Attached Thumbnails SC10 4x4 Thread-img0467.jpg   SC10 4x4 Thread-img0468.jpg   SC10 4x4 Thread-img0472.jpg
Old 05-17-2013 | 10:28 AM
  #34058
Tech Legend
Default Sc 10 4x4 Light Setup
Chassis Brace Mod
Lowers chassis brace about 4mm
Helps reduce body roll, makes truck feel less tippy.
Also the front brace gains leverage & strenght.
The mount screw will not bend as easy & break .
* remove the spacer from the front mount & grind 4mm off the rear mount
Old 05-17-2013 | 10:42 AM
  #34059
Tech Legend
Ae's unbeatable QUAD pad VTS Slipper
Makes for smoother handling and improved traction , less wheel spin , better landings off jumps...
* add 1 Ae metal VTS slipper ring & 1 VTS slipper pad
* use the Ae heavy duty pad behind the spur gear
* adjust lock nut so the threads are just below the nylon on the nut
*use lock tight on slipper nut
Old 05-17-2013 | 10:48 AM
  #34060
Tech Legend
Default Ae Sc 10 4x4 Light Setup
Reedy 4100 65c Shorty
helps reduce weight & smoother body roll , better jumping & landings
*reduces weight of truck about 100 grams compared to saddle packs.
*use the Losi foam blocks , they fit just right...
Old 05-17-2013 | 10:58 AM
  #34061
Tech Legend
Motor cover, belt cover's & back plastic back plates
Removes excess top weight , makes for less chassis roll.
Truck will feel less tippy....
* Remove rear motor & belt cover & plastic back plate , no mod nessesary.
*Remove front cover
Attached Thumbnails SC10 4x4 Thread-img0482.jpg   SC10 4x4 Thread-img0478.jpg   SC10 4x4 Thread-img0481.jpg
Old 05-17-2013 | 11:05 AM
  #34062
Tech Legend
coming soon
Candrell's belt tensioner mod
complete set-up details
Old 05-17-2013 | 11:12 AM
  #34063
All those mods and truck still can't hang with the losi or teckno, give it up.Guys
rickybobbyxxx is offline
  #34064
Tech Legend
Forgot
My truck weights 5.2 lbs body , tires & shorty..
all of it makes for speed you will appreciate when leading or chasing the other trucks ....
ricky
you will never become a winner by giving up and trying to buy instead of working & earning the reward of victory....
Old 05-17-2013 | 11:20 AM
  #34065
Cain's Avatar
Tech Legend
I think this is an area that AE can improve, access to the diffs. A few changes here and there and they would be golden.
I'd be curious to see how that diff comes apart for that 1/8 buggy that looks like a clone of the SC10 4x4.
Cain is offline
