Like Tree5Likes
SC10 4x4 Thread
Old 04-10-2013 | 08:19 AM
  #33751
drolmaeye's Avatar
Originally Posted by rhys
No top end, a 2 wheel buggy went past me. tekin 550 5.5 sc4x. orion vortex R8 pro. M12 epa set at 150.
Most people going with a 550 can are running 4.5T motors. Assuming you are using 32 pitch gears and you are running 62/14, you are geared more for a 4.5T motor. In short, I think you need to go up a few a couple teeth in your pinion. But I would search this thread for successful gearing for this motor size and Kv range.
If your track is small to medium size and tight/technical, 5.5T could be great, but for large tracks you may want to consider going up a bit in Kv on your motor or turning up motor (or even better, dynamic speedo) timing for the straight(s). I'm sure you don't need me to warn you to keep an eye on temps.
Generally you should never let a 2wd buggy pass you. Proper track etiquitte is to swerve wildly to discourage any attempted pass. If the buggy driver still insists on passing, let them get ahead and then plow into their rear on the next corner.
drolmaeye is offline
Old 04-10-2013 | 08:25 AM
  #33752
Wink
I love it!
warrenwrench is offline
Old 04-10-2013 | 08:27 AM
  #33753
rhys's Avatar
Lol. Ok will try and go up pinion. Small track, the track in Gaithersburg Maryland indoor. Thanks
rhys is offline
Old 04-10-2013 | 08:42 AM
  #33754
Wild Cherry's Avatar
Tech Legend
I would only give you a couple chances
first to show proper etiquette ...
Then ?
My B4's wheel will be your reward each time after if you insist on trying to order take out .... ..
Wild Cherry is offline
Old 04-10-2013 | 08:47 AM
  #33755
Don't make it any tieter or the belt will pop off u need the brace
9turn is offline
Old 04-10-2013 | 09:17 AM
  #33756
dominick i.'s Avatar
Suspended
("Generally you should never let a 2wd buggy pass you. Proper track etiquitte is to swerve wildly to discourage any attempted pass. If the buggy driver still insists on passing, let them get ahead and then plow into their rear on the next corner")
wow, i guess you have been training all of the 4wd sc guys out here also
dominick i. is offline
Old 04-10-2013 | 12:18 PM
  #33757
you should be fearful on who you do that to. i have seen a guy car get wreck cause some one did that to him. do this really mad guy walked down grab this guy car and beat it on the ground
imrob is offline
Old 04-10-2013 | 12:27 PM
  #33758
Tech Legend
Not to mention fueling more bad for the Sc class.
More better to show respect & set
a good example instead of a bad one ....
Old 04-10-2013 | 12:56 PM
  #33759
Cain's Avatar
Tech Legend
agreed. It amazes me to see or hear about guys throwing fits because they can't control their vehicle or handle more technical sections of the track. Or, yelling at marshalls when they crashed their car.
Cain is offline
Old 04-10-2013 | 12:58 PM
  #33760
If you can't out dive a 2 rd with this truck u need more help than I can give
9turn is offline
Old 04-10-2013 | 01:46 PM
  #33761
ok thanks for the info i'm gonna get that upgrade kit it comes with the new slipper and and hardware needed for the upgrade
imrob is offline
Old 04-10-2013 | 05:03 PM
  #33762
rhys's Avatar
It was only on the back straight.
rhys is offline
Old 04-10-2013 | 06:27 PM
  #33763
Tech Legend
@ The Track
Going though a buddy's ride with the Exo chassis
Just started with the tear down..
This truck had been so abused ?
Call-n 911 ....lol
Old 04-10-2013 | 06:34 PM
  #33764
???E-Racer's Avatar
Going to be racing my 4wd SC10 here soon hopefully.
They almost have the track built.
???E-Racer is offline
Old 04-10-2013 | 09:29 PM
  #33765
Tech Legend
Demanding lots pictures & video ......
