Like Tree5Likes
SC10 4x4 Thread
Old 03-26-2013 | 08:02 AM
  #33451
I'm real curious about BK's servo mounts from a few pages back. I like the idea very much, and the front end comes apart nicely without the servo on the top plate. 2wd mounts only kinda work, they need to be spaced up 4-5mm for the servo to clear the X on the chassis. I have an idea for making some mounts, we'll see what I come up with.
16mm shocks for sale, if anyone's interested. They worked well on the truck, but I just think that since I drive at an indoor track 99.9% of the time, I'm not seeing as much of a benefit from them. When my track had a whoops section, the 4x4 with the 16mm BB's killed it...but there usually isn't a whoops section. I think they'd rock an outdoor/rough track.
maddysdaddy is offline
Old 03-26-2013 | 08:17 AM
  #33452
Cain's Avatar
Tech Legend
Originally Posted by TomErickson
So as I update my SC10 4x4 I am planning to remove the belt tunnel. Is there any reason to keep it? I am a racer and will be racing on all types of tracks from hard packed clay to soft loamy dirt. Should I be concerned?
If you plan to run an inner tray or the outerwears filter, I personally could see you running without the tunnel assuming you are not fouling the gears with dirt. The main thing you get from the tunnel in my opinion assuming the chassis is sufficiently braced (exotek chassis or the chassis brace) is dirt protection for the belt.
heck, I have wondered if you could save a bit of weight with a lexan cover of sort.
Cain is offline
Old 03-26-2013 | 08:26 AM
  #33453
Wild Cherry's Avatar
Tech Legend
If you are using 4oz + ballast the 16mm do help ..
Feel the 13mm outperform the 16mm if you use little to no ballast however ...
If you are using the Exotech chassis the 16mm shocks will perform better dealing with its extra 6 oz addition of weight also.
Wild Cherry is offline
Old 03-26-2013 | 08:42 AM
  #33454
Originally Posted by Wild Cherry
kool to hear Max got her done ...
That was a big Moto cross style track layout with big -O-jumps ...
I saw his TQ run but didn't see the A-main. I was in the C-main and did a whole lap and a half then connection broke to dean connector off ESC to battery.
The track was huge and ended up being brutal to the 1/10 trucks. Pot holes that swallowed up the truck .
This was my first trip, plan to go back many, many more times.
Will try to post some video.
MunchMunch is offline
Old 03-26-2013 | 09:17 AM
  #33455
Cain's Avatar
Tech Legend
LOL heard that from the Tekno guys too who finished in the top 5.
Looking forward to your vids!
Cain is offline
  #33456
Tech Legend
Getting a big kick reading the Tekno guys asking just how far behind their ride was from Max's Sc10 4x4 ...O-Man !
Old 03-26-2013 | 09:56 AM
  #33457
Cain's Avatar
Tech Legend
what you mean this?
Originally Posted by Cain
For the Pyscho Nitro Blast, how close were you guys to the overall winner with the sc10 4x4? How would you compare the handling you saw between your Tekno's and the sc10 4x4?
I did find this part interesting, maybe you didn't get to it:
Originally Posted by Bernard_Jr
... To answer your question. Max's SC10 navigated the turns well and he found great lines but he had to double single the triple most of the time. The few times I saw him try it he crashed or barely drove away from it.
I was able to keep the super tight lines where necessary and could of pushed my Tekno harder through the rough stuff but you always run the risks of a bad bounce or a break at that track and played it safe. Out of the 22 laps we did between the two mains I probably hit the triple 19-20 times only letting up if there was traffic.
Chris Viesins (TQ) also looked like he had trouble with the triple and double singled most of the time.
After 20 minutes of driving Max and I did 22 laps and I was 39 seconds behind.
Maybe those 16mm shocks would help in those conditions?
Ultimately though, I get a bigger kick out of this at the 0:36 mark:
+ YouTube Video
O-Man!
Cain is offline
Old 03-26-2013 | 11:04 AM
  #33458
I removed mine and have 0 issues. I am running on two different types of dirt specifically, a hard packed clay and a hard packed but dusty dirt... not sure what to call it lol.
Anyways, I don't run the spur protector nor do I run the clicker protector either, and I'm actually going to shave down the plastic around the belt a bit more also to clean up the look.
Again, I've had 0 issues with this and find it helps when I start to tear down to either refill a diff or need to get to my servo for whatever reason.
CaseyDDR is offline
Old 03-26-2013 | 11:08 AM
  #33459
ryanpatrickgore's Avatar
No belt tunnel is sooo 2012... Haha jk
Full tunnel is making a comeback in 2013!
ryanpatrickgore is offline
Old 03-26-2013 | 11:48 AM
  #33460
cantrell8's Avatar
somethin I did saturday (no belt cover)
http://tweakstation.files.wordpress....24_1259030.jpg
cantrell8 is offline
Old 03-26-2013 | 11:57 AM
  #33461
Jstall7543's Avatar
I like the belt cover. Gives me a good place for a sticker or two. As we all know stickers make it faster.
Jstall7543 is offline
Old 03-26-2013 | 12:32 PM
  #33462
i only run it because once in a blue moon ill drive it outside at my house or the park with my wife. sure i could just install it back on.. but then i would have to install it back on.
Old 03-26-2013 | 12:34 PM
  #33463
totally doing this.
CaseyDDR is offline
Old 03-26-2013 | 01:43 PM
  #33464
sugs's Avatar
This is a great idea for those that don't want the front cover. I tried running with no front cover for a race or two but found that the belt started to come off at times and upon closer inspection I found that the front guide pulley flexes easily without the cover in place so I put it back on.
sugs is offline
Old 03-26-2013 | 05:30 PM
  #33465
CraigMBA's Avatar
I think he did it to stiffen the front part of the chassis in twist. I'm just speculating, but it makes sense. Same thing for that cute carbon fiber brace.
CraigMBA is offline
