Like Tree5Likes
SC10 4x4 Thread
Old 06-29-2012 | 10:45 AM
  #25801
samuelsonmark71's Avatar
So thats the b4.1 hub? Interesting, let us know how it works out
samuelsonmark71 is offline
Old 06-29-2012 | 10:47 AM
  #25802
Wild Cherry's Avatar
Tech Legend
Default Catch-n da Grief
Originally Posted by jamr1130
Well I know I'll catch alot of grief for this but I have to agree with WC on this one. I tried the Reedy Sonic 4.5 550 last night on a new layout at my local track. The track is full of tight turns and no jumps bigger that doubles this layout. The Reedy really shined
plus 1
Wild Cherry is offline
Old 06-29-2012 | 10:48 AM
  #25803
Tech Legend
+1
Old 06-29-2012 | 10:56 AM
  #25804
Wildcat1971's Avatar
A lot of people come here trying to go "faster". I always assume they are racing their friends up and down the street and most of the advise given is to help them drag race. But when it comes to the track, sheer horsepower and speed hardly ever win the race. I have always been faster with a stock motor in my b4 than a mod motor. One way to make my lap times crap is ad a bunch of speed. But... If your a pro level driver and can handle and utilize the power to your advantage, then its butter. So like 2% of us need max horsepower for racing. I run a reedy 540 7.5 and I can keep up with everyone in my skill level. I just have to watch my temps.
I recently had an issue like mentioned above with speed. I was running a 13.5 in my b4 buggy. And there was a double that literally everyone cleared. Even the novice drivers with their rtr kits cleared it. But I was casing the jump. I was running my esc blinky even though no one else did. It was blinky from MOD the week before when I ran a 10.5. So, I went into the esc and added 20% of variable timing. Ran a few laps and temped at 120ish. I was now able to clear the jump, but the little added power was not over whelming. BTW it was not a hard jump, it was just spaced far apart on the back straight. Like I said all of the novice could do it clean. Anyway, just thought I would share.
** Also, I agree with cherry about smooth power. I would never keep a motor that was not smooth.
Wildcat1971 is offline
  #25805
Tech Legend
+1
Old 06-29-2012 | 11:01 AM
  #25806
vito's Avatar
love my novak 550 4.5 trun it dose ok. am at 12 62 and in the mid 30 mph is its sound right speed ?
vito is offline
  #25807
drolmaeye's Avatar
Originally Posted by Wild Cherry
+1
One more and YOU will have cleared the quad. j/k
drolmaeye is offline
Old 06-29-2012 | 11:19 AM
  #25808
Originally Posted by Krio
Punch control meaning Current Limiter (CL on the esc interface). If you are running 100 in hotwire under the current limiter then you are allowing any and all current to pass through. If you drop this setting to 80 or so you should notice a drop in temps at the motor with minimal change in punch. The lower you go the cooler everything will run, but the less punch the motor will get.
thanks for the reply.
Unfortunately I'm not running an RX8 or my RS Pro in my SC10, I have a Hobbywing 120a ESC, the one that can run 1 cell.
In the punch setting it is called Start Mode and labelled level 1 to 9.
I have it on 1.
I have boost timing on 0 degrees and turbo timing off.
I drove it today and although I spent a fair bit of time avoiding kids who wanted to chase it round the track it felt better for having the drag brake removed and a little cooler at the end of a pack. Moving the rear camber link inboard and changing to front blues all round helped as well.
Beachbuggyphil is offline
Old 06-29-2012 | 11:22 AM
  #25809
Jake S's Avatar
Originally Posted by t0p_sh0tta
I stole somebody's plastic B4 hub idea. I'll be giving it a go on Sunday, if I can find a replacement spur gear.
wow didnt think about using the b4.1 b-tabs, looks like you actually get 3 holes of adjustment on camber length lol, using the plastic b4 hub i still really only getting "1" and "2" in relationship to the standard sc104x4 hub.
Jake S is offline
Old 06-29-2012 | 11:29 AM
  #25810
Originally Posted by drolmaeye
My last Wed. night race was in May (the race shown in the video). Let's just say I was not in the top three. In fact, I think I may have started the main along side you if your truck is the one I'm thinking of. These days I'm mostly just going on practice nights to get more wheel time, learn how to drive, etc. On the 11th I am on call at work. But I'll def keep an eye out, and will be back to Wed racing probably on the 18th.
I was there that night. Had to restart the main when 1/2 the field wrecked in the first turn! You don't see my truck much in that video, mainly due to the fact that I was no where near as fast as those guys! Keep an eye out for me on Wed's. I'm there pretty much every week now. Still trying to learn to drive like the big boys.
Snafujg is offline
Old 06-29-2012 | 11:35 AM
  #25811
t0p_sh0tta's Avatar
Originally Posted by Jake S
... using the plastic b4 hub i still really only getting "1" and "2" in relationship to the standard sc104x4 hub.
I'm sorry, but I'm not sure what you mean. The optional "C" hub that everybody is running is shorter than the plastic "A" and "B" hubs. I should be over 8mm.
t0p_sh0tta is offline
Old 06-29-2012 | 12:20 PM
  #25812
Jake S's Avatar
hubs have 3 holes that change turnbuckle length (camber). if you use the C towers or b4 plastic you only get the 2 inner holes for "length" in comparison to the stock sc104x4 hub.
but using the b4.1 b tower like you did it looks like all 3 holes line up very well. any chance of a straight on shot from the back? any chance of you measuring the increase in height from stock ballstud?
Jake S is offline
Old 06-29-2012 | 12:22 PM
  #25813
Try if your wheels fit over them first. I tried to use them and the inside "spokes" of the stock wheels caught on them so the wheel wouldn't turn.
Arakon is offline
Old 06-29-2012 | 12:34 PM
  #25814
SMR 510RR's Avatar
You really only get 1 and I guess -1 on the carbon ones unless you run them toward the outside by a hole on the bottom.
SMR 510RR is offline
Old 06-29-2012 | 12:40 PM
  #25815
Jake S's Avatar
ahh idk didnt mess with them i just used a plastic b4 hub i had laying around, clears the rims easily, and since i got to drill my own holes i could go from +7 to +10, but did go +8 lol.
my outer hole lines up with the middle on stock
and middle on mine lines up with inner on stock.
i have never really liked a shorter link in the rear, so tried to find my own way around it without getting some g10 lol
Jake S is offline
