SC10 4x4 Thread
While changing to 11t Pinion i noticed, that my chassis-plate damages the motor-case! there's a big scratch in the chassis-plate, where the motor hits the chassis when landing and the motor case has some "optical" damage. Is that normal, or is my motor just too long? it's a tenshock with 4600kv
Thanks! I was fixing out home pc when I ran across these in my box. Busted out my calipers and then went and found some extras. The stock stud does have to be cut down about 4mm to fit though.
When I charge @ 20 amps, it does not hurt to balance and add 1 minute to the charge time and at that rate I would rather be on the safe side and balance.
Different story I guess if you are charging at a snails pace 1c when all you got is 5 to 6 amps going in.
New tech lipo's rock
5Likes
