Like Tree5Likes
SC10 4x4 Thread
Old 05-31-2012 | 07:51 AM
  #24286
Cain's Avatar
Tech Legend
Originally Posted by Snafujg
I'm looking to get this and noticed in the description it mentions an Aluminum Rear Hub. I'm not running an aluminum one, I'm running the original plastic one. Can I still use this with the plastic rear hubs?
http://www.amainhobbies.com/product_...-C-Tower-Set-2
I think they are mainly referring to the fact that these are originally designed for the aluminum hubs on the 2wd stuff. There usage on the 4x4 is something new specific to this 8mm mod.
Cain is offline
Old 05-31-2012 | 07:55 AM
  #24287
Awesome. Thanks Cain and Evil.
Snafujg is offline
Old 05-31-2012 | 09:00 AM
  #24288
BorackBasher's Avatar
what will the c hub tower do to the car? handling wise? i have a set of carbon tours just sitting around.. pro and cons?
BorackBasher is offline
Old 05-31-2012 | 09:01 AM
  #24289
Evil Genius jr.'s Avatar
Give the rer more traction mid-exit of a high speed sweeper.
Try them, you may like or you may hate it.
Evil Genius jr. is offline
Old 05-31-2012 | 09:29 AM
  #24290
ok i will try them today.. i will let you know my results this evening.. seems like my rear end is still unpredictable.. likes to dance coming into the sweeper and exiting the sweeper.. i just wish the car would be consistent and not so unpredictable! i can have a few consistent laps and when i want to push just a little more it gets all hay wire!
Old 05-31-2012 | 09:36 AM
  #24291
FRONTI3R's Avatar
Since you are raising it 8mm... Just remember to add (Most run 7mm) washers under the inner ball stud if you do the 8mm Mod.
FRONTI3R is offline
Old 05-31-2012 | 09:42 AM
  #24292
While changing to 11t Pinion i noticed, that my chassis-plate damages the motor-case! there's a big scratch in the chassis-plate, where the motor hits the chassis when landing and the motor case has some "optical" damage. Is that normal, or is my motor just too long? it's a tenshock with 4600kv
Cody227 is offline
Old 05-31-2012 | 09:56 AM
  #24293
for the c hub tower mod? at the moment i only have 2 ballstuds in the inner hole at the moment.. when i put the c hub tower on do i have to raise the inner hole to 7mm?
Old 05-31-2012 | 09:58 AM
  #24294
You don't have too. Play around with it and see what you like.
Old 05-31-2012 | 10:00 AM
  #24295
If you do the c-hub mod and raise the outer ball stud 8 mm, you need to raise the inner by 7-8 as well to truly benefit from the mod. Otherwise you will not only have a completely different roll center than those running the mod, you will have a much higher camber gain rate which will probably make for a worse off car than just leaving the ball studs in their stock location.
Krio is offline
  #24296
ok i will.. what if i do add more ballstuds to the inner hole.. what will that do to the car handling wise? more stable or less stable?
Old 05-31-2012 | 10:01 AM
  #24297
i wll try both! thanks krio
Old 05-31-2012 | 10:20 AM
  #24298
SOuthernFRIED's Avatar
The higher I raised the inner ball stud the more stable my truck got. 7mm is the highest you can raise it and still get the ball stud to screw into the mount without modification.
SOuthernFRIED is offline
Old 05-31-2012 | 10:28 AM
  #24299
I have some computer m3 standoffs I am going to try. Will raise the ballstud up to 11mm
Old 05-31-2012 | 10:53 AM
  #24300
Voila!
Raises it 8mm or higher up to 12mm
