SC10 4x4 Thread
#1966
NEW!!! Pro Team Edition 6200 mah 60C 2S 7.4v hard case Lipo pack!
$65
http://www.promatchracing.com/products.php?cat=21
$65
#1967
$65
$65
Pro Match is here in Havasu and that is the battery I'm running in my SC10
4x4. The battery "ROCKS"
#1970
$65
$65
Got sick of waiting for hobbypartz to get batteries in stock
#1971
Hey again guys, im having a bit of troubles still with the trucks setup. Now i run on mostly dusty 1/8th tracks, and currently my setup is:
30 weight in the front-no rebound-bladders
25 weight rear- no rebound- bladders
over drive in the front
stock ride height, but lowered in the back to make equal front to back.
5mm washers under the front ballstuds
And im running m2 calibers all the way around.
Now the truck is quite good, but still fairly loose in the rear. On long sweeping corners it wants to drift out, and sometimes on the tight corners too, if i get too carried away with the throttle.
Anyways i was just wondering if this can be fixed or helped any further? It just seems like the truck has way too much give in the back.
#1972
I found a Ebay seller in germany who sells them, I bought the 50C 5A 2s1p Gens Ace.
Germany is next door for me, so shipping isnt that bad
#1973
With all this wheel talk it has me thinking...
I placed an order for three different sets of tires last week and nobody had the stock wheels at the time, so I nabbed up some sets of the Jconcepts SC10 4wd wheels. Has anybody used them yet? Mine should be here today or tomorrow.
#1975
#1978
Glad to see you've got a good sense of humor, I'm sure it looks pretty cool mounted up on the truck, I actually really like the Lime green, but then again I was born in 1973, so...hahha And yep, I'm sure it's easy to pick it out of pack of trucks that all look the same.
#1979
Glad to see you've got a good sense of humor, I'm sure it looks pretty cool mounted up on the truck, I actually really like the Lime green, but then again I was born in 1973, so...hahha And yep, I'm sure it's easy to pick it out of pack of trucks that all look the same.75 here so I'm used to the wild candy paints "corvette summer" once I pick it up ill mount it and post picks.
#1980
takes a bit longer then I used to. and sometimes it tells me it is full but on a other charger its not..
5Likes
