Like Tree5Likes
SC10 4x4 Thread
Old 03-09-2012 | 09:47 AM
  #18901
ilanstylz's Avatar
Originally Posted by SCTDan
Curious why a 2 pole 550 and not one of the new 4 pole 550's?
He probably only mentioned the 2pole 550 cans because 4pole 550 cans are not roar legal........
ilanstylz is offline
Old 03-09-2012 | 09:49 AM
  #18902
Originally Posted by ilanstylz
Thats why I didn't recommend the gens saddle pack, the tenshocks are known to be power hungry and I think at a 25c rating will cause the lipo's to run hot when used with the tenshock...... I'm no expert so its up to you if you want to try them.......
I hear ya, I'm considering the Turnigy Nano-techs 5100 65-135c saddles as they are reasonably priced. Any experience with them or know anyone that has run them with the sc411 4000? Thanks for the help guys, it's always a bummer to order something in rush and have it not work out the way you planned.
FTsc104x4 is offline
Old 03-09-2012 | 09:53 AM
  #18903
Cain's Avatar
Tech Legend
I have seen these asked about a few times and they have been stated to be good. just make sure you get expedited shipping or you will be waiting a LONG time.
Last race I ran some Hyperion 30C 6000mah batteries. They are the fat style like the Gens ace packs and worked really well. Temped under 90 degrees after a full run when the motor was temping hot. Since they are hyperion, should be good quality and for the price I got them for new, worth a shot.
Cain is offline
Old 03-09-2012 | 10:06 AM
  #18904
Mizchief's Avatar
I run gens ace 40c 5000mah on my sc10 4x4 with no issues at all so you should be good to go...... Actually I just ordered some 5000mah 50c gens ace so I want to see how those perform as well....
I wasn't very happy with mine. About half way though the pack and the truck starts to studder pretty bad for me. I mainly use mine as a backup for my 2wd truck and vmx 450
Mizchief is offline
Old 03-09-2012 | 10:11 AM
  #18905
Mizchief's Avatar
I run them with the pro4. They work pretty well an are rated for 10c charging. I also get some shudder with them off the line at around the 12min mark which ins't a problem for actual racing.
Mizchief is offline
Old 03-09-2012 | 10:15 AM
  #18906
Mizchief's Avatar
Yea UPS 3 day is the best. I can usually order on sunday and get stuff before the weekend and I live in the southeast and it goes though the KY hub so the closer you are to KY the faster you will get them.
I always factor in that $30 shipping when pricing batteries. Sometimes it's worth it for the savings (I think those saddles are like $25) other times I'd rather pay an extra $10 - $30 to get the name brand with some support.
Mizchief is offline
Old 03-09-2012 | 10:19 AM
  #18907
Does the shudder you mentioned happen all the time from the different Nano-techs or most of the batteries you run? Also, after running saddles, were you overly impressed with the performance or was it a small increase in handling? Thanks again!
Old 03-09-2012 | 10:28 AM
  #18908
JEFFs SC10's Avatar
Originally Posted by Chad Smith
Do not buy the Gens Ace 6000 mah packs. They are to tall and require you to make your own battery strap. The b44 battery post and straps will not work because the batterys are so tall. I am running the gens aces for now and they work fine. Just get the 4800's.
4800 wont last long.
I run the 6000 with no problem. But then again I have Mantis' saddle pack setup with the straps.
Def go 6000.
I run a savox, pro 4 4600 and rx8. These batteries work fine. I'm sure I pull enough amps. Would I like like more c rating ? of course but I'm not paying out the yang for it. Maybe if I had a different budget I'd spring for something like a Reedy but I'm far from being a Ryan Maifield.
JEFFs SC10 is offline
Old 03-09-2012 | 10:37 AM
  #18909
Originally Posted by Evil Genius jr.
speaking of hobbywing.... What is a good hobbywing ESC for this truck? It will be used with a catsle 1410 on 2S.
Love my HobbyWing XERUN-150 amp!
sbrewer is offline
  #18910
Def go 6000.
I hear ya on the "out the Yang" for some of these batteries. Do you know off hand if the FT saddle strap setup is the same as Mantis' or will it only fit the 4800mah size saddle packs?
Old 03-09-2012 | 10:38 AM
  #18911
Mizchief's Avatar
The shudder could just be me, and one set does it more than the other, and like I said it's only after 12mins or so of runtime on the nano-techs where the gens ace 5ah 40c did so very early in the pack and feels like it starts to dump voltage early.
The nano's feel pretty much the same right up until cutoff. When racing I usually take a couple of hot laps before the heats and main to burn off that initial jolt, then it's good to go with consistency for the rest of the race.
I love the way my truck drives right now, but I did exotek, saddles, and center diff all at the same time so it's hard to say what exactly did what.
Mizchief is offline
Old 03-09-2012 | 10:44 AM
  #18912
JEFFs SC10's Avatar
You can go to gens ace and get the dimensions of the battery and maybe see in the manual (available online rc10.com) to see if they'll fit with the factory saddle girdle.
They aren't too tall where they won't clear the belt cover. It should work.
Call up AE and speak to Chris Jaroz he might know off the top of his head.
I forgot I had a copy of the FT manual here, it looks like you can adjust the height of the battery strap. Look at page 39 of the FT manual.
Old 03-09-2012 | 10:47 AM
  #18913
alex4r's Avatar
You can use the Gena 6000s with b44 setup, BUT you will have to get longer set screws for the thumb screws if you want to use them. I am just using a regular 4-40 screw for now until I find longer ones. Might just have to get a long button head and run it all the way through the thumb nut. I didn't have to make different straps though.
I didn't seem to feel a huge difference in handling until I started using the 6000s at a big race last weekend that had an indoor track with a ton more traction than my local track.
alex4r is offline
Old 03-09-2012 | 11:10 AM
  #18914
So just to recap u guys running front springs on the rear, whats the benefit of doing that and which springs are u using??
rickybobbyxxx is offline
Old 03-09-2012 | 11:16 AM
  #18915
JEFFs SC10's Avatar
Better spring rate. Im running blues.
