SC10 4x4 Thread
7k oil would be like driving the same car now equipped with a locker in the rear that transfers power more equally to both tires in the same turn and now your back end is swinging out (over steer) and your lookin like Tanner Foust slidin through the turn all fast & furious style.
Lighter oil, less oversteer.
Thicker oil, more oversteer.
For the front:
Lighter oil, less push (more steering)
Thicker oil, more push (less steering)
Easiest way to describe it is the 3k oil would be lile driving a limited slip rear diff equipped car through a turn on power and the power would transfer to the Wheel with the least traction (inside) and you would get some tire smoke but thats about all the excitement you'd get.
For the front:
For the front:
Not that but they do
http://www.amainhobbies.com/product_...al-Rebuild-Set
They were out this morning, hmm.
http://www.kenonhobby.com/search.asp....y=8&search=GO
I would the the force of the gear rotation would throw the grease outward and leave only a thin coat on the gears. If the thin coat wears off, whats is protecting the gears? Does the grease move back into position well?
5Likes
