SC10 4x4 Thread
http://www.youtube.com/watch?feature...&v=ziL1j-l799k
Not to mention if you are the guy going double-double and the guy behind you is going fast enough to triple-single, or worse, go quad. Get well soon Trey Canard.
| + YouTube Video | |
The shock towers are supposed to hold the hex-shaped part of the shock mounts and prevent a turning of the mount when installing the lock nuts on either side. All four of them ended up spinning freely because the plastic was too weak to hold the hex. Any known fixes? I had to claw down on them with needle nose pliers to be able to tighten the nuts.
Oh, and if you're not running a clutch basket, you might want to put a couple of 1/4" washers between the spring and the slipper plate. If you don't, your nut will bottom out on the threads and the part of the shaft that flares out before your spring is fully compressed. Go into your local hardware store and pick up a few...they're like $0.10 each, and you can also use them between your body and the body clips to distribute the stress and help prevent your body from tearing through a body-clip.
Is it normal for the body to (almost) rest on the rear bumper? A big "boo" towards Team Associated for that body, btw.. I've never seen one that thin before, along the sides I just cut clean through the lexan with a scalpel when I was just scoring the surface without much pressure.
Many "race" bodies are thin, especially when you start pulling the lexan into the large SC body shapes. The same thickness of lexan pulled into a buggy body will remain thicker than one pulled into a big SC body. For practice and club racing, I actually run a slash body with modified mounting holes, because I know it will hold up much better than any of the racing bodies. For big events, I'll still run a Flo-Tek or Hi-Flow body.
I know a bunch of people here run the LRP X12L, what is your gearing? I can't test the truck at the track yet (won't open for a month or two yet), but it's a track with a bunch of tight turns, a long straight, and a triple jump. I usually run 20-25 minutes per battery with my slash 4x4 there. I currently have it set up at 14/62, but want to order another pinion if that is considered too high.
Yup, I think that was changed in the 2nd or 3rd batch of trucks going out. The original shipment had the diffs prebuilt with 3000/3000 and it was virtually undriveable like that.
i really prefer the 2wd SC class at basher's, i think it is more fun than 4wd much of the time. 4wd SC is usually not as big of a class either. the layouts are so technical that you really learn throttle control with 2wd. speaking of which, there should probably be a new layout coming sometime soon....
The FT truck should be called the RT (rc tech) truck. The added all of the things that popped up on this thread. Well, except for the shock bodies, Ti turnbuckles, and aluminum screws and hexes.
I have been reading this hole thread and it's awesome.I have my sc10 4x4 for sale though because there isn't a big enough class at my local track. I'm asking $220 OR BEST OFFER paypal. If any one wants pics or has questions PM me. If you want pics make sure you send your email adress to.
Thanks,
Dan
Thanks,
Dan
i agree that some of the guys on this thread have come up with and made some great improvements on this truck as i have purchased some of them and i tip my hat to them for their ingenuity ....
At 80bajillion pages and many random posts, the only thing not mentioned in this thread is the mating habits of the elusive Himalayan tree beagle. Now that I have officially mentioned that, I think we're done.
Is it just me overlooking something, or is the only way to access the diffs to basically disassemble most of the truck?
The 4x4 is faster and much heavier than the 2wd and will beat the body a bit more, but the factory body isn't bad. Nice and light, not a lot of weight up top.
5Likes
