SC10 4x4 Thread
#9481
Flange was melted to the cover. I have a spare cover but waiting for the pulleys. Bolts in the trans were not sticking through the belt cover...I had read here about that maybe being an issue. This thread is a wealth of knowledge thanks to all that have posted. No play on the top shaft and no lawn darting. Is it possible I cranked down the clicker too far?
Thanks again to all who answered. Pics not an option at the moment so I hope the description will do.
Sal
#9482
The flange was completely shredded up inside the the pulley too! I think that Chris Jaroz was right and that the belt tension was way too tight. Thanks again for the responses!
Sal
Sal
#9484
Thanks again for all the help. Waiting for parts so time will tell. Will post up pics as soon as I can.
Sal
#9485
Associated sells a FT shock kit...but the ONLY difference is TiNi shock shafts and different color shock bodies. No need to upgrade the shock IMO...just buy the TiNi shafts and maybe some Trackstar O-rings and you'll be golden. If you are really looking for the best possible shock then maybe try polishing the pistons with a dremel, a polish wheel and some red jewelers rouge (you'll find this wherever dremel products are sold).
~Edited to reword some things.
#9486
Oh, I see now. Even tho it is pinned I may still try it. i would like to know for my sakes if the shim behind the plate would have helped. Why exactly does this go behind the plate. The nut in the front seems to squish the plates together tight enough or am I missing something. But ya, the basket in the long run will be the ticket. 35$ bucks isn't going to break the bank. I just feel the same as you and think the other solutions could/would have worked. Thanks
Terry
Terry
#9487
Okay, so I wasted an idler today. A front one.
See the two marks?
It's important to make sure you put the right screws back in this truck where they claim they go. In this case, the ones that held the shocktower. The screws were 4mm too long, and, well, whoops. Good thing I ordered extras.
Does anyone know what the sway bar color code equates to in size?
See the two marks?
#9488
Terry
Terry
At that point. you add one more washer. That's it. I'd show a pic, but I JUST put my truck back together 20 minutes ago. =D
Edit: $^$# It. I'll take a picture to show all of this. For you guys who are having trouble and are hesitant on more money.
#9489
See the two marks?
See the two marks?
White=1.8mm
Blue=2.0mm
Yellow=2.2mm
#9490
You have a Bare top shaft. Then that collared spacer goes on. Then the bearing. *teflon deal with ball bearings inside* Then the metal washer.
Also I wanted to know much tension does everyone have on there belt. I read some say loose while others a little tight. The way I check is rolling the truck on the ground. If it goes at least 5 feet with a slight push I call it good. It's hard to tell if there's to much or not enough. This to me could create a ton of drag which would affect the motor, esc, and batteries.
#9491
Okay.
This is about where I run my slipper on a normal Fun day. 1mm off flush. I'm protecting my idler this way. (remember, I've gone through 2) This slips pretty good. And what I mean by that is it protects the gears and gives me enough power to do anything I want minus a wheelie. It warms the housing. (before the spacer, it used to be hotter than the motor damn near) Pointing out it's only 1mm from flush. I have days of travel left to lock it down as I stated previously for the wheelie idler blowing action.
This is my Slipper assembly. Those pads are my original pads mind you. The dust from the belt housing gets all over them and makes it look bad. Wipe them down and a little sandpaper and they're good as new.
This is my Thrust bearing.
1: The collared piece
2: Bearing
3: Steel washer
4: The additional teflon washer
That washer turned my truck into a wheeler producer. No belt rub from moving the pulley forward. I'm on the original Belt. Etc.
I loved my truck when I put that spacer on it. Then I fell farther in love when I pinned the truck. There ya go. So ya know.
2: Bearing
3: Steel washer
#9492
Ran my SC10 4x4 on Sunday, I love this truck, heaps of steering and rear grip, the power that comes from the Tekin RX8 and 4600kv Pro4 motor is mind blowing, Esc temp 119f and motor 124f geared 13/64.
Ran the MTK clutch basket with the garodiscs, what a combination they are, all I say is if your not running them do so
Just fitted the RcShox stage 2 pistons and the RPM front/rear arms, very interested on how they will back this beast handle.
#9493
With it pinned, they should all look the same when you disassemble it. I don't think any debris did that to that pad (only heat) because it is super hard to get any dirt in there with it clamped down. IMO that's heat. And if it warms the housing, it's too hot. IMO.
#9494
You need the basket more than a fat kid needs cake. The fact you can build enough heat in the slipper pad to discolor it that bad, man....no bueno.
Oh, and yes.
...I do need Cake.
Edit: Oh and btw. Those pads like I said are from 3 months of pre-pinned meyhem.
#9495
5Likes
