SC10 4x4 Thread
#1547
What do you guys think about me using a JR9000T servo in the SC 4wd? I know it is definately overkill, but it is what I have available.
Torque shouldn't be an issue, but speed might be. I'll be using a MMP ESC, probably paired with a 1410 motor.
ben
ben
#1548
I'm using it!! Can't be happier, just make sure you set endpoints properly!!!
#1549
I am using a 9100s working great
#1553
I'm getting somebody to do that with mine as well. The son of the owner of the local track does painting. He's just a kid starting out, so I'm not expecting it to be killer. But I hate painting so I figured I'd let him try it.
#1554
I think I have a decent sway bar set up.
I used sway holders from my Xray T3 2011
http://www.amainhobbies.com/product_...Holders-T2-008
Some parts from a Losi Ten SCTE sway bar kit.
http://www.amainhobbies.com/product_...-Bar-Kit-Ten-T
and I bent some 2mm music wire. You can even use set screws and yes the bumper clears. I just finished the front and will do rear tomorrow.
great idea w/Xray sway holders!
#1555
Its a level line between the bottom of rear transmission and the edge of the ft kick plate, this how the team drivers advised me personally ...
#1556
If anyone is experiencing glitching issues with the MMP try adjusting the EPA for your steering so there is no servo stress when the wheels are turned each direction. I ended up with the EPA set around 71(left) and 81(right). The random resetting of the MMP stopped. Luckily I tried this before I bought the external BEC.
#1557
any gearing idea for Tekin RS esc no boost/turbo just C1 default 80* timing, Redline 8.5? ran stock spur with 19pinon then started walking down to a 15. esc keeps hitting thermal shutdown. threw a 88spur and followed the same to bring temps down and motor wasnt getting over heated, esc keeps hitting thermal.
#1558
#1559
#1560
From: Norwood, OH...and CCRCR and The OhioRCFactory
5Likes
