SC10 4x4 Thread
#796
Nope. The cartridge tube separates the X-ring's so when you remove one it doesn't affect the other.
#797
Wow, that is good stuff Chris. Wish I had all those tips before I put the thing together
Will be good to know for a rebuild though. Especially the loctite on the servo screw...I'm guessing that may force a teardown and rebuild soon...
#798
im confused i though it was 5k or 6k that was recomended not 50 or 60k .
#800
#803
Hey guys, here are some build and race tips that myself and some guys here at the office have come up with. Some of this stuff is in the manual and some of it isn't. If it's in the manual, we just put it in because it's extra important.
Build Tips
1. Make sure to use Factory Team thread lock, #1596, on your servo horn screw.
2. If using an XP Digital servo, use the servo horn labeled (F).
3. Make sure to apply a small amount of black grease, #6588, on the servo saver halves, page #7, before building the servo saver.
4. Use a bit of Green Slime, #1105, on the 91005 paper diff seal to help prevent fluid leakage from the differentials.
5. Be sure to add 1 ball stud washer, #9630, on each of the M3x26 and M3x24 transmission case screw, page #13.
6. The screws for the rear transmission case, #89226 (M3x26) and #89225 (M3x24), do not have to be completely tightened down. They just have to be snug enough to hold the motor plate. Over tightening can cause drag in the drive train. Be sure to use Factory Team thread lock #1596 before installing the screws as well!
7. When assembling the clicker assembly page #11, apply a drop of Factory Team Tire glue, #1597, to the nylon on the adjustment nut this will help to prevent the nut from backing off. Also use a small amount of black grease #6588 on the clicker teeth to keep it quiet.
8. Use a very small dab of Factory Team Tire glue, #1597, to hold the threaded ball stud inserts, #91021, into the shock towers.
9. Be extra careful to use the correct screws to hold on the front hinge pin brace! Double check that they are 10mm long ones, #25620 Page 18, and not 12mm in the rest of that part of the build. Using too long of screws can cause the front transmission to bind.
10. Make sure to apply some Factory Team thread lock #1596 on the inner ball studs pages 14 & 15. This will help prevent them from loosening up while running.
11. Use a very-very small drop of Factory Team tire glue #1597 on the wheel hex pins #91027 shown on page 16 & 20. This helps keep the pins in the axles when you remove the wheels or remove the hexes.
12. Make sure to apply some Factory Team thread lock #1596, to the shock piston screw. Doing so will help prevent the piston from falling off.
Race Tips
1. Remove the upper X-Ring, #91055, this will free up the shocks and takes a lot of the stiction away and the shocks will feel much smoother. Don’t forget that the shock cartridge seal tube is directional!
2. Use our high-torque slipper pad, #91170, on the outer slipper hub only; refer to page 28, when using 550 motors.
3. If you are running without shock boots, #91070, on the shocks, you must add up travel limiters to avoid damaging the bladder.
4. When running bladders, you can remove the bleeder screw to reduce the air-spring effect caused by the air being trapped above the bladder.
5. Adding thread lock, #1596, will help the wheels nuts from backing off during operation.
Build Tips
Race Tips
#804
#806
The Traxxas serrated nuts are aluminum. I used them on my SCRT10 and stole them from that to use on my SC10 4wd. They work great, and even match the other AE aluminum parts.
#809
For those that are still looking we just got in 10 more kits in & with also have parts are server was down & live inventory will be updated
http://www.superiorhobbies.com/istar...id=ASC90004!SH
Also anyone looking for a 2wd we have a sale going on
http://www.superiorhobbies.com/istar...&id=ASC7027!SH
#810
Does anybody have any good setups for a bigger, outdoor track? All the setup sheets AE has posted say blue groove, dusty, etc. I'm looking for something more towards a tacky, rougher outdoor track.
5Likes
I had a lot of questions about the new shocks, that seem to take care of them.
