#7322
I was not lacking torque with my old setup. Gearing up brought the motor back to life but I think one more tooth and it will be there. I need to test back to back to see what effects it has on runtime and motor temps as well as lap times to see which one I want to stick with. I should know more after I race this weekend. (assuming I get to go Sat!)
#7323
I ran the 16 tooth last night with the 4.5 and rotor and hit 150 after 7 minutes on an outdoor track that has decent laps around 30 seconds. I added 3600 mah back to that pack. What do you think will happen if I goto a 18 or 19 pinion? Just trying to get a guess as my assumption would be more heat and less runtime. Then again I have read where some motors hit their sweet spot when you gear em up (or correctly) and the opposite happens.
#7324
what's the point of owning this POS truck anyway, Losi doesn't seem to want to replace anything, also my center diff won't hold oil and I'm thinking about just sending this stupid truck right back to their front door. Any ideas without spending any money to fix it?
#7325
Just send it too me , I will happily dispose of it for you .
#7327
has nothing to do with me being in the "wrong hobby" it's common sense, make sure your product isn't a pile of garbage then let the consumer spend 300$ for that garbage. It's sad that you think that it's the consumers fault. You should probably get off of the internet before you make yourself sound even more completely retarded.
#7329
I understand man, but it's just completely utterly impossible to think they're taking this problem seriously.
#7330
Who said I thought it's your/the consumers fault, Your pantys are really wadded up because your seeing stuff now ?
#7332
Not flaming sir, annoyed that I payed 300$ for something that doesn't work for more than 2 quals, and an A main. Losi will help, whether they like my attitude or not. I should have probably just bought a slash.
#7335
I get the impatience from my father, It's inevitable for me to not. I am sorry for the name calling, just a tad heated about the issue. Especially the wait for fixes.
