![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
It shouldn't be that difficult to get a measurement on a pin. You got 4 chances....lol. It'll be an even size, probably 3mm.
I think its gonna be 2.5mm x 8 or 10 mm . I was hoping to hit a hobby shop while I was out and about today but Ill get the measurement tonight and go from there . Thanks for your support and replys . Ill be sure to let the thread know what I come up with .
That could be. I just had an scte in the shop I could have measured them for ya.
UPDATE : I was able to use a traxxas wheel hex pin . They are the same diameter but just slightly shorter . I going to run them and see if they cause any problems . If they do I'll get the losi hex and pin kit for it .
2mm diameter (both losi and trx)
9.80mm length (losi)
9.70mm lenght ( traxxas)
This is the most newbie question I could ask, but I have never run into this issue before:
What size wheel nuts go on this thing? In the manual, the diagram does not give a part number for them. On A-Main, some m4 nuts are listed as being good for the SCTE 1.0 (which is what I have), 2.0, and 3.0. Others say they only fit the 2.0 and 3.0. And then others like the Yeah Racing ones say they will fit the SCTE 1.0 and the Associated SC5M... which is ABSOLUTELY not true... because I have the SC5M and the wheel nuts DO NOT fit. I already ordered a set off ebay that don't fit, so now I have a 6 dollar bag of trash to toss into my toolbox and I don't feel like rolling the dice again. Thanks guys. If you can link me directly to the direct replacement, or some other wheel nuts you KNOW will fit because you've used them yourself, then it would be greatly appreciated.
There has to be some kind of variance in manuals then, because my manual has every part number listed EXCEPT for that part. I asked my LHS about it, and when the guy looked it up, he was just as baffled as me to find that he didn't have that one part number listed either. I'll take a pic if I can and show you what I mean. EVERY part number is listed in the exploded view except that one.
These are normal m4 nuts. Nothing special. Several cents in every nuts store
these are normal m4 nuts, several cents in every nut shop
