When are the HA camber and steering ball ends coming out? I have a ton of slop and don't really want to put the stock ones back in. I thought they were suppose to be released by the end of November.
Thanks Casper. Now if I go to 5/5/3 from 3/3/2, will it handle similar since all the weights have been increased? Honestly, I liked the way the truck handled with the stock grease. I just had issues with the truck starting to diff out once I added the power of the RX8/Pro4.
Which inside tire? Front or rear?
What do you mean diff out? I was recently running a MMM and 3800, which I just upgraded to an RX8/ Pro 4 4600 and I am constantly fighting my truck under hard braking and exiting turns. My truck wants to drift all over the place. Im running 5/3/3. Im thinking about putting 5 in the center to help with more of a 4wd effect and transfer more power up front. Am I on the right path?
been running 5/7/2 i started at 3/3/2. was thinking of trying 3/7/2
Ok sounds good. I think now with the 4600, 3k in the center sounds like it's to thin. The track I run on his a high traction track and I think im sending way to much power to the rear.
Ill try 5k
Ill try 5k
You guys got it backwards...
The lighter the diff oil the more power the front wheels will see when accelerating.
Under acceleration the weight of the truck shifts to the rear. So under high traction situations the rear hooks and lifts the front. The thicker the center diff, the more power transfered to the back. For example if you were to put 50000wt in the center the truck would wheelie. If you put nothing or 1000wt in the center the front tires would balloon like crazy.
Same thing with the front. When turning on power the weight shifts to the outer rear of the truck. Thick fluid helps direct the power to that outer front wheel and helps pull the truck thru the corner. Thinner lets the diff unload (spin one out drive and not the other) and blaze that inner front wheel with no traction.
heres a good article for more reading...
http://www.myrcbox.com/articles/tech...gy-and-truggy/
might want give 7-5-3 a shot if your on High bite tight track lots of rip.
has anyone tried 5/5/5 in the diffs?
how did it drive/rotate?
Im using 3-5-3 in my truck and i drive on a medium bite,sometimes dusty ,about medium sized track and it works great.
