Like Tree9Likes
Old 11-20-2011, 08:09 PM
  #24586
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
Originally Posted by cm.stites
what setup are you running
Running a stock set up with oil in the diffs.
kjohnsiii is offline
Old 11-20-2011, 09:07 PM
  #24587
DBL15's Avatar
Originally Posted by Benny 13
how are you guys stacking up to the sc10 4x4's in TIGHT indoor tracks? will be moving to tight indoors were this truck dominated big outdoor
it will completely dominate on tight indoors like it did for you out doors mate
i was running mine on a 40 foot x 30 foot track that was 5 foot lanes at the most and out of 18 rounds losi SCTE won 16 of them
DBL15 is offline
Old 11-20-2011, 09:12 PM
  #24588
EricInNeenah's Avatar
Thumbs up Traction Roll
Originally Posted by kjohnsiii
Can someone help please. I am running on a high bite track and trying to dial out some side
Side bite out. I keep traction rolling.
are you running at 27mm ride height or below? I had to get the new tuning spring pack to achieve 27mm in the rear..i think with the stock springs you can get 28mm with the collars all the way up. I followed the the dakotah phend setup , and my scte corners much more planted instead of skipping through turns or traction rolling
hacker: are you guys trying anything new on the scte setup for Trackside?
EricInNeenah is offline
Old 11-20-2011, 09:51 PM
  #24589
builthatch's Avatar
this is the first vehicle i've ever bought that wasn't a kit, aside from mini-zs and one tamtech.
i'm incredibly particular and build static models as well, so i like to think that i build things with great precision.
how would you rate the build quality on the truck? i'm the type that goes over everything and cuts/files all flashing, reams holes that might be off, uses purple loc-tite (or better, depends) on all screws, etc.
builthatch is offline
Old 11-20-2011, 09:56 PM
  #24590
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
Build quality is good, but if your the type... Take the time and completely dissassemble it and put it together your way. You will enjoy it too! It's not that bad!
thecman26 is offline
Old 11-20-2011, 10:05 PM
  #24591
KingdomRacer's Avatar
I'm impressed with the purple loctite as it is what I only use too and most are not even aware as it being the correct thread locker to use with such small fasteners.
KingdomRacer is offline
Old 11-20-2011, 10:15 PM
  #24592
builthatch's Avatar
yep, some people don't even know it exists! i've gotten some funny looks looking for it, haha. stuff is great. just enough to keep things from vibrating out without gumming anything up.
Old 11-21-2011, 07:36 AM
  #24593
The quality is pretty good. I pulled out all of my diffs before running it and there was more than enough grease in the gear boxes and diffs. 2 of the screws holding the battery tray in from the bottom of the chassis were stripped from the factory though
Keeferton is offline
Old 11-21-2011, 08:09 AM
  #24594
xxfile's Avatar
If youre gonna do a complete tewar down buy a set of Tony's screws to replace all the screws a lot of the screws are of poor quality and strip easily so be careful and make sure you have good wrenches when you disassemble
I had no problems but some on this forum have stripped screws
xxfile is offline
Old 11-21-2011, 08:27 AM
  #24595
Casper's Avatar
Trader Rating: 34 (100%+)
They build the cars well. The few I have looked at have screws tight and all that. I would recommend tearing it down and going over the car if you are going to race it though. There are always little things we all do to make sure arms are free and shocks are properly bleed etc that help when racing.
Casper is offline
Old 11-21-2011, 08:37 AM
  #24596
elex300's Avatar
Trader Rating: 110 (100%+)
I di a tear down right out of the box. Replaced stock diff pins with Chris pins and filled with fluid. Been runnin strong for five weekends at the track. I'm impressed the most with the amount of steering these have.
elex300 is offline
Old 11-21-2011, 08:40 AM
  #24597
Asharus's Avatar
Trader Rating: 42 (100%+)
+1
Tony's set is awesome, worth the investment.
Asharus is offline
Old 11-21-2011, 08:48 AM
  #24598
dtr
dtr's Avatar
Mine was built pretty well, even the servo saver was locktited. The only issue was two of the screws in the front diff were strongly overtightened, so it was impossible to get them out without a dremel. Of course you're best off going through the whole car before running it, for peace of mind.
dtr is offline
Old 11-21-2011, 09:10 AM
  #24599
Trader Rating: 62 (100%+)
new to rc without reading 1600 pages what do you guys use to clean old diff oil and junk out of diffs when rebuilding and re oiling diffs?
buckeyenut73 is offline
Old 11-21-2011, 09:41 AM
  #24600
chucko's Avatar
hot water. tooth brush Dawn dish washing liquid cleans better then tooth paste
chucko is offline
