Cool thanks. I notice'd some of the plastic was cracking a bit, and stretching.
I have seen that I go faster with unstrapped tires than I do with strapped tires.
I have not dived into back to back testing to offer a better explanation of why.
But... I definitely think the factor of added weight to the wheels as part of the drivetrain can be a big factor and also how the tire does not swell up which actually adds to speed is why I probably have seen what I seen.
Due to my experience with strapped tires with my 4s setup in my buggy I have never tried it in my 2s setup since I have always felt it would prove to be more unnecessary weight to my drivetrain on such a taxed out system (2s) to begin with. I agree though that my last statement can be seen to be more true for heavier SCT's than lighter ones.
Now... If 3s was a much more approved V in my area I definitely would have already strapped tires for my SCT and would have a little bit more to add in relation to SCT's.
I have been very curious about this myself for my 1/8 scale since strapping tires has given me an advantage of running more closer center diff weight to a nitro setup versus the actual diff weight you really need with all the power a 4s setup gives you that usually leads to such an unloading to the front tires making them balloon up.
It has been my experience that strapping tires helps when needing to run a lighter center diff weight when racing on blown out tracks. Which is why I am on the fence still about not having a couple of strapped sets for those tracks.
And, now I read in the Serpent thread that some are countering the front unloading through stiffer rear springs in keeping the front down to limit the unloading which is something I have never considered as an option.
Maybe a thread on others experiences in racing conditions could offer more insight?
Good Job Josey! I had it out last night with 3 other SCTE`S and a couple ae`s and got Rooted by one of my bud`s like 4 times in the Main and just having a really smooth run.One like I have not had in a while! Tonight s club race got to throw down some Revenge.. While the # 1 truck got to take advantage that 2- and 3 were slugging it out,, it was a Battle to get in front of this mini-Rival and stay there! Truck is soo Sloppy with the OG pivot Balls and needing a serious Tune-UP, but It kicked But! 2nd Place? Fun !..Payback and 2nd Place PRICELESS!
and u were even quaddin that double/triple section
one possible explanation is when the tires grow under acceleration, your overall final drive ratio goes down (numerically) which gives you more top speed potential. it's a sliding scale though. when the rear tires are on the ground digging in, they are closer to their stock size upon acceleration because the weight transfer taking place and the lower wheel speed. the tires are close to their stock size so you get the torque multiplication you expect with the transmission ratios and the gearing you have. but as you reach terminal speed, the truck unloads more evenly, lightens up and the tires both front and back grow, and now your final drive is going down which increases your top speed. it's like gradually adding teeth to the gearing as you are moving along.
faster as far as overall lap times, or faster terminal speed on straights?
Back to your question, I am still considering both parts of my next sentence in my post to be a much bigger factor together than individually as I believe your response would suggest that it is only due to the lower FDR.
I am going faster for both the lower FDR as well as the weight of the tape that would only seem logical and really not too much of a surprise to anyone.
Where I am still on the fence is more of handling issues and which one can give better handling, that is where I would need to dive into that more, lol.
Study Question on body clips
Are these: http://www.amainhobbies.com/product_...all-10-Micro-T the replacement clips for the receiver box?
and is this http://www.amainhobbies.com/product_...-Body-Clips-12 for the body?
never had any problems with the STRC stuff i have brought
I was wondering if you are shaving down the steering linkage at all? When using the inside hole with a Hitec my steering range is greatly reduced because the linkage contacts the servo body before full throw. Thats why I went back to the outside hole.
I know some servo cases are different. If you cannot get full throw with it on the inside, then I agree, you would want to use a different hole or even a different horn. Maybe just asjust the steering expo a shade off center.
R/C Tech Elite Member
He said use a different hole!
BTW I am using the Racers Edge Aluminum arm. Maybe I will try the Losi.
how are you guys stacking up to the sc10 4x4's in TIGHT indoor tracks? will be moving to tight indoors were this truck dominated big outdoor
